Help! Octocam cant connect to IP address
Hi i’ve just bought the octocam and don’t seem to be able to connect to its IP address (through Firefox, with Kaspersky security). It keeps timing out. Admittedly i accidentally broke the clip for the camera slot but still managed to get it to clip back in. Could this be the issue? The only other thing i can think of is firewall…? Please help an amateur Pi user.
sorted, Fing app was giving incorrect IP to connect to. After connecting Pi to monitor i found another IP to try. this worked. :D
Glad to here you fixed it!
Another alternative is to go to your Wifi router’s settings and double check the Raspberry Pi’s IP address there; I use it quite often when SSHing since I haven’t bother to set a static IP. :)
