I was fascinated by the Hilbert curve and looking for something different to display using my Unicorn HAT.
After a fair bit of reading, researching, drawing and a lot of trial and error I came up with the following python code (lots of which came from https://people.sc.fsu.edu/~jburkardt/py_src/hilbert_curve/hilbert_curve.html).
I hope this proves interesting/uesful to someone else.
#! /usr/bin/env python
## Hilbert_Chase.py
## Author : Craig Thomas (Honorable mention to John Burkardt for the complex maths)
## Created : 2017.03.27
## Inspired by the Raspberry Pi, Unicorn HAT and the Hilbert Curve
# https://en.wikipedia.org/wiki/Hilbert_curve
## John Burkardt's code
# https://people.sc.fsu.edu/~jburkardt/py_src/hilbert_curve/hilbert_curve.html
## Other Useful links:
# https://shop.pimoroni.com/products/unicorn-hat
# https://github.com/pimoroni/unicorn-hat
# https://learn.pimoroni.com/tutorial/unicorn-hat/making-rainbows-with-unicorn-hat
# Import statements
import unicornhat as uh
import colorsys as col
def d2xy ( m, d ):
#*****************************************************************************80
## D2XY converts a 1D Hilbert coordinate to a 2D Cartesian coordinate.
# Licensing:
# This code is distributed under the GNU LGPL license.
# Modified:
# 03 January 2016
# Parameters:
# Input, integer M, the index of the Hilbert curve.
# The number of cells is N=2^M.
# 0 < M.
# Input, integer D, the Hilbert coordinate of the cell.
# 0 <= D < N * N.
# Output, integer X, Y, the Cartesian coordinates of the cell.
# 0 <= X, Y < N.
n = 2 ** m
x = 0
y = 0
t = d
s = 1
while ( s < n ):
rx = ( ( t // 2 ) % 2 )
if ( rx == 0 ):
ry = ( t % 2 )
else:
ry = ( ( t ^ rx ) % 2 )
x, y = rot ( s, x, y, rx, ry )
x = x + s * rx
y = y + s * ry
t = ( t // 4 )
s = s * 2
return x, y
def rot ( n, x, y, rx, ry ):
## ROT rotates and flips a quadrant appropriately.
# Licensing:
# Modified:
# 03 January 2016
# Parameters:
# Input, integer N, the length of a side of the square.
# N must be a power of 2.
# Input/output, integer X, Y, the coordinates of a point.
# Input, integer RX, RY, ???
if ( ry == 0 ):
# Reflect.
if ( rx == 1 ):
x = n - 1 - x
y = n - 1 - y
# Flip.
t = x
x = y
y = t
return x, y
def timestamp ( ):
## TIMESTAMP prints the date as a timestamp.
# Licensing:
# Modified:
# 06 April 2013
# Author:
# John Burkardt
# Parameters:
# None
t = time.time ( )
print ( time.ctime ( t ) )
return None
def draw ( x, y, r=255, g=0, b=0 ):
# Function to draw a pixel a particular colour on the unicorn HAT and pause
uh.set_pixel(x,y,r,g,b)
uh.show() # Show the new pixel
time.sleep( 1.0 / 10 ) # Pause for 1/10th of a second
return # End def draw
def d2xy_walk ( ):
## D2XY_WALK runs D2XY.
# Partly my function
# import platform
#import unicornhat as uh
#from time import sleep
#import colorsys
m = 3
n = 2 ** m
print ( '' )
print ( ' D X Y R G B' )
print ( '' )
huemax = 10 # Number of steps in hue to take to cover the entire range
for hue in range ( 0 , huemax ):
# For each hue step
for d in range ( 0, n * n ):
# For each pixel
x, y = d2xy ( m, d ) # Get location on grid
rgb = col.hsv_to_rgb( (1.0 * hue) / huemax, 1.0, 1.0 ) # Convert HSV stepped colour to RGB
r = int( round (255 * rgb[0] ) ) # Set R, G and B values
g = int( round (255 * rgb[1] ) )
b = int( round (255 * rgb[2] ) )
draw ( x, y, r, g, b ) # Draw the coloured pixel
print ( ' %3d %3d %3d %3d %3d %3d' % ( d, x, y, r, g, b ) ) # Text Output (debugging)
# End for d
# End for hue
print ( '' )
return # End def d2xy_walk
## The MAIN program starts HERE
# If being run as the primary program (not a module)
if ( __name__ == '__main__' ):
# Set up Unicorn HAT
uh.set_layout(uh.HAT) # Set layout to 8x8 Unicorn HAT - Default anyway?
u_width,u_height=uh.get_shape() # Get the shape
uh.rotation(0) # Set rotation
uh.brightness(0.5) # Set the brightness
uh.off # Clear the board
timestamp ( ) # Timestamp the start
# Run the Walk?
d2xy_walk ()
timestamp ( ) # Timestamp the end
## End of the File
