Motephat LEDs flash when changing brightness after a few minutes
I have a single mote stick and a motephat on a rpi 2 (stretch upgrade of jessie) and motephat 0.0.2. I have made a small script that fades the brightness up and down after on all the LEDs after pressing enter. All the pixels set to a specific RGB setting (warm white RGB 255/110/40) before the main loop.
If I press enter the LEDs fade up as expected, I press enter again and the LEDs fade down as expected. If I only leave a few seconds between pressing enter all is fine.
However if I leave the LEDs in the ‘off’ state (brightness 0.0) for a minute or more once I press enter I get a quick flash of at least full RGB 255/255/255 full white before my script sets the brightness and the correct colour and brightness is restored. I even get it when I Ctrl-C the script.
Here is the script.
import motephat
rc = 255
gc = 110
bc = 40
motephat.clear()
motephat.show()
    input("Enter for on ")
    for b in range(0, 11):
            bv = b / 10
            motephat.set_all(rc, gc, bc, bv)
            motephat.show()
    input("Enter for off ")
            bv = (10 - b) / 10
            motephat.show()
    motephat.clear()
    motephat.show()
Is there anything I am doing incorrectly in the script that could cause the flashes?
I’ve also noticed that sometimes that when I have had the flash of white some pixels don’t always have the right colour. Pressing enter a couple of times in quick succession fixes the colour.
Any ideas or suggestions welcome.
Thanks.
Graham
UPDATE: It appears that as long as I make a change to a pixel every 10 seconds (not tried other periods) the flashing does not occur.
UPDATE: Looks like even just writing the intended state again is good enough. Could my Pi or Motephat be dodgy?
Hmm… This may be something to do with you using the brightness function. I’ve had trouble with using “brightness” on a couple of neopixel sticks before, so it may be a similar issue.
When you’ve set the brightness to 0, try setting the colour to RGB 0, 0, 0 as well, which should in theory set the LEDs to a non-coloured state.
Set up a test to see if I can replicate this.
I now have green spots in my vision.
Leaving it off for a minute to see what happens.
And… I can’t seem to replicate your issue. Curious!
However…
Now, for…
The Technical Explanation
Okay. So the APA102 pixels are basically a set of tiny shift registers, each with its own memory. These pixels remember what you told them- so if you say “Be green!” they will happily sit and be green for as long as you like until they’re told to do something else.
Or… if random noise happens to look enough like a signal they might decide to light up or change colour seemingly of their own accord. All they need to assume a signal is valid is a sequence of three 1s 0b111, then the next 5 1s are the brightness, and the following 24 are the colour… so…
If you happen to get any kind of interference close enough to Mote pHAT it’s likely to induce something close to a signal on both the clock and the data line, basically shooting a stream of 1s into the APA102 pixels and making them blindingly 100% on.
This might not be what’s happening in your case, but it’s likely.
The Fix
As you’ve found out for yourself, the best fix is to simply keep the pixels updated. You suggest every 10 seconds, but ideally you’d just have your while loop constantly update them at a sensible framerate that depends on how smooth you want your brightness transitions to be. Not so fast that your Pi’s CPU is eaten entirely by pixel updates, but fast enough to eliminate the chance of random noise causing rogue lighting output.
And this is what you’ll find most things that drive APA102 or WS2812 pixels will do- constantly update the pixels.
Now I normally don’t rush to give out code examples, but I think this is a good opportunity to demonstrate how I’d accomplish this sort of program- paying particular attention to the smoothness and timing of effects and the need to output constant updates to the pixels:
import motephat
import sys
import select
# Note it's conventional to use ALL_CAPS to denote constant values
# that we don't expect the program to ever change during runtime.
# Updates per second
# A higher number consumes more CPU but gives smoother transitions
FPS = 60
# Speed of the transition, higher is faster
# Due to gamma weirdness, turning on always feels faster than turning off
# since most of the high-end brightness steps are the same
# A higher speed will look smoother at higher frame rates
SPEED = 1.0
# The colour to display
RED = 255
GREEN = 110
BLUE = 40
# Internal state
brightness = 0.0
lights_on = False
motephat.clear()
motephat.show()
print("Press enter to toggle...")
# This is a non-blocking (doesn't stop our code from running while it waits)
# method for getting a character from stdint (Standard Input) which is where
# the text you type into your Python program goes when you hit enter.
# select is a method for checking if there's anything there before we try to read.
def get_char():
    if select.select([sys.stdin], [], [], 0) == ([sys.stdin], [], []):
        return sys.stdin.read(1)
    return None
    # Get a char from the standard input
    char = get_char()
    if char == '\n': # Look for a newline chr(10), ie: enter key pressed
        lights_on = not lights_on # Toggle the lights
        print("Lights {}".format("on" if lights_on else "off")) # Print the current status
    # If lights should be on and the brightness is less than 1.0
    # then start increasing the brightness each step
    if lights_on and brightness < 1.0:
        brightness += 1.0 / 255 / FPS * SPEED * 100
        brightness = min(1.0, brightness)
    # If lights should be off and the brightness is greater than 0.0
    # then start decreasing the brightness each step
    elif not lights_on and brightness > 0:
        brightness -= 1.0 / 255 / FPS * SPEED * 100
        brightness = max(0.0, brightness)
    # Show the current state of the LEDs
    # This happens continuously even when brightness is not changing
    # In this instance we set global brightness to always be 1.0, because the APA102s
    # only have 32 steps of brightness, which doesn't make for smooth transitions at all
    # By scaling the values themselves we approach 256 steps, eight times as many!
    # Note: Global brightness is only really useful as a set-and-forget limit on brightness
    motephat.set_all(int(RED * brightness), int(GREEN * brightness), int(BLUE * brightness), 1.0)
    motephat.show()
    # Sleep a little,
    # In this instance we're working to an approximate framerate, so we
    # we sleep by 1 second, divided by the number of frames we want in a second
    time.sleep(1.0 / FPS)
Even this code isn’t perfect. You will probably notice that the LEDs appear to turn off slower than they turn on. They’re actually transitioning through the steps at the same speed each way, but the changes in the higher-end of the brightness are much less perceptible than those in the lower end.
Also, you might notice red/green kicking in first. This is a problem that this method introduces that’s less pronounced when you use global brightness.
Thanks for the detailed response.
My target platform is going to be some Pi Zero Ws and all they will do is listen for network messages and then run some predefined pattern over the mote sticks. So 10 second updates aren’t going to tax them at all.
Thanks,
Graham
