OctoCam - Constantly failing to connect to Wireless Network
Hi everyone,
Today I received my OctoCam. Everything has been fine, up until the point where I turn it on and plug it into my monitor. It gets to the stage Starting wpa_supplicant: failed (brcmfmac), before rebooting itself.
I have read a couple of other topics with a similar issue, however those resolutions did not work for me. I am on a Mac, and I have used TextEdit (converting to plain text), Sublime, and TextWrangler, to no avail. I have also tried with both my Virgin Media SSIDs (2G and 5G), with that not working either. Here is my wpa_supplicant.conf file:
update_config=1
ctrl_interface=/var/run/wpa_supplicant
network={
    scan_ssid=1
    ssid="VM761553-5G"
    psk="password123"
Hopefully there’s a resolution to this - it’s starting to get frustrating!
Thank you.
I am having the exact same issue, the wpa_supplicant file continuously fails to start. I have the correct ssid and password but nothing. I hope that someone replies with a possible solution.
have the same thing here
it does work wired (usb-ethernet dongle and cable to my lan)
any help would be greatly appreciated
made the sd card again and now wifi also works - mystery
Note the WiFi access point name and password are both case sensitive, which can certainly be a tripping point.
@roddyefc23 is the “5G” on the end of your SSID indicative of a 5G-only network that your access point serves up? Is there a non 5G version? The Pi Zero W does not support 5Ghz WiFi, so this would certainly fail.
