Hello,
I’ve solderd my On/Off shim and it works great! Installing the software was easy.
I’d like to know if:
is it possible to use the on/off shim also as a reset button (for example: press the button 5 seconds to initiate a reboot/reset?
I’m using the shim for a digital signage project. I wonder if it is possible to have the pi startup after an unexpected power outage, without having to press the on/off button. Now when there is a power outage, the pi automatically starts up after power is restored and this is very convenient :-)
Reset function - in principle, yes! I’ll pass that on to the team as a feature request. :-)
Auto start on power cycle - you could create this functionality by adding a latching circuit to the “BTN” header. Essentially if you make it so that when power returns the circuit emulates a button press then it could start the Pi up automatically.
