On/Off shim heavy on resources
Hello,
I’ve noticed, since I’m using the On/Off shim on my pi, the temperature has risen quite a lot.
Before it was below the 50 degr celcius.
Now is it around 66-68 degr celcius.
I was going to use this on a digital signage project, but it is on a window facing south. so this could give overheating issues?
kind reagrds,
Christophe
I believe we found that was due to a bug and fixed it very recently, you should try reinstalling the software and it should make a big difference.
Indeed! Did the update and temperature is back to normal levels.
Thanks!!
