So, it looks like some time recently the apt repo referenced by the OnOff Shim is down, and serving 403 Forbidden
to anyone trying to access it. This, of course, breaks the script and means the OnOff shim isn’t much use without the repo/package/script.
Heres the output:
$ ./onoffshim
This script will install everything needed to use
On/Off SHIM
Always be careful when running scripts and commands copied
from the internet. Ensure they are from a trusted source.
If you want to see what this script does before running it,
you should run: 'curl https://get.pimoroni.com/onoffshim'
Support for your operating system is experimental. Please visit
forums.pimoroni.com if you experience issues with this product.
Do you wish to continue? [y/N] y
Checking environment...
Updating apt indexes...
............W: Failed to fetch http://dl.bintray.com/pipplware/dists/jessie/main/binary/./Packages 403 Forbidden
W: Failed to fetch http://dl.bintray.com/pipplware/dists/jessie/armv7/binary/./Packages 403 Forbidden
E: Some index files failed to download. They have been ignored, or old ones used instead.
Apt failed to update indexes!
I’m guessing the Pimoroni guys should probably know about this, and I’m sort of hacking a replacement together now, but does anyone have a mirror of the original repo?
