OnOffShim script not installing correctly on Batcera Linux
Hi. New to Raspberry Pi’s and your company. I’m using your onoffshim, ssh’d into my Rpi3 running Batocera Linux (https://batocera-linux.xorhub.com/) - a fork of Recalbox. Tried instaling the script via:
curl https://get.pimoroni.com/onoffshim | bash
Got loads of errors:
login as: root
root@Tomodore74’s password:
curl [removed b./c your forum onlyu allows 2 links! bleh] | bash
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 38496 100 38496 0 0 209k 0 --:–:-- --:–:-- --:–:-- 262k
This script will install everything needed to use
On/Off SHIM
main: line 136: tput: command not found
Always be careful when running scripts and commands copied
from the internet. Ensure they are from a trusted source.
If you want to see what this script does before running it,
you should run: ‘curl [removed b./c your forum only allows 2 links! bleh]’
stat: invalid option – 'f’
BusyBox v1.26.2 (2017-06-04 09:08:00 CEST) multi-call binary.
Usage: stat [OPTIONS] FILE…
Display file status
    -L      Follow links
    -t      Terse display
main: line 280: /106: syntax error: operand expected (error token is "/106")
main: line 140: tput: command not found
Running as root, please log in as a regular user with sudo rights!
# curl [removed b./c your forum only allows 2 links! bleh] | bash
-sh: fg: %: no such job
-sh: Dload: command not found
-sh: 100: command not found
-sh: This: command not found
On/Off SHIM
-sh: On/Off: No such file or directory
-sh: main:: command not found
-sh: Always: command not found
-sh: from: command not found
-sh: If: command not found
you should run: ‘[removed b./c your forum onlyu allows 2 links! bleh]’
-sh: you: command not found
stat: invalid option – ‘f’
-sh: stat:: command not found
-sh: syntax error near unexpected token `(’
-sh: Usage:: command not found
Display file status
-sh: Display: command not found
-L Follow links
-sh: -L: command not found
-t Terse display
-sh: -t: command not found
-sh: Running: command not found
Any advice?
thanks
Also tried it on Recalbox - exactly the same errors…
