I’m intending to use the pHAT DAC with a RPi as a demonstartor for a system that will use the same DAC (PCM51xx).
Would it be possible for you to divulge the components hanging on the left and right outputs of the DAC please? Better still would be a snippet of the actual pHAT DAC circuit diagram :-)
Are they the same as the ones on the Texas Instruments evaluation board as per the diagram below?
