Picade PCB Help - Two players?
I’m running a workshop in the summer for a dozen people who want to make a Picade built into an Ikea coffee table. I’ve done this myself with a one-player build using a Picade HAT, and found it to be a great piece of kit. And the table is fantastic!
For a two player build however, would we need to use one Picade PCB for each player’s set of controllers, i.e. two attached to each Pi?
I like the Picade set up because it just works, the wiring loom and screw connectors are fantastic for beginners. Is this the most appropriate for a two player setup? What would you recommend? I’d like to keep the build instructions fairly straightforward.
Many Thanks!
Loz
see this topic, discussed recently:
http://forums.pimoroni.com/t/picade-hat-2-player-ver/4727/3
Excellent, thank you :)
