Pimoroni pHAT DAC pin use
I’ve setup a Raspberry Pi B with Shairport to AirPlay music to my speakers. Works a treat, however the audio quality is poor and volume is low. I’m therefore looking to add external sound to fix both these issues.
Also considering replacing the Pi B with a Pi Zero.
Problem is I’m also using GPIO to turn my speakers on and off via a relay.
I was wondering if the Pimoroni pHAT DAC used all the pins? If not, which ones are available for other use?
Thanks for you help!
Brendt
It uses the pins detailed here: http://pinout.xyz/pinout/phat_dac
Plus 5v power, and ground of course.
pHAT DAC supplies a line-level output, so it likely wont help for your low volume problems- that’s really down to the amplifier to solve.
Thanks! I’ve placed an order with an Australian supplier.
