Pirate radio spotify
Hello
It’s now five times that I try to install my “Pirate radio” with the script to use “Spotify” but I still have the same error message during installation:
"Configuring mopidy …
ERROR Failed to load iris extension: No module named spotipy
File “/usr/lib/python2.7/dist-packages/mopidy/ext.py”, line 202, in load_extensions
extension_class = entry_point.load (require = False)
File “/usr/lib/python2.7/dist-packages/pkg_resources.py”, line 2190, in load
[ ‘name’])
File “/usr/local/lib/python2.7/dist-packages/mopidy_iris/init.py”, line 7, in
import handlers
File “/usr/local/lib/python2.7/dist-packages/mopidy_iris/handlers.py”, line 5, in
from spotipy import Spotify
ImportError: No module named spotipy
patching file /home/pi/.config/mopidy/mopidy.conf
Hunk # 1 succeeded at 24 (offset -1 lines).
Hunk # 2 succeeded at 34 (offset -1 lines).
Hunk # 3 succeeded at 38 (offset -1 lines).
Hunk # 4 FAILED at 61.
Hunk # 5 succeeded at 60 (offset -7 lines).
Hunk # 6 succeeded at 77 (offset -2 lines).
Hunk # 7 succeeded at 108 (offset -17 lines).
Hunk # 8 succeeded at 131 (offset -17 lines).
Hunk # 9 succeeded at 133 (offset -17 lines).
Hunk # 10 succeeded at 149 (offset -17 lines).
Hunk # 11 FAILED at 183.
2 out of 11 hunks FAILED - saving rejects to file /home/pi/.config/mopidy/mopidy.conf.rej "
Can someone help me?
thank you
Jessie or Stretch? If Stretch, try Jessie instead.
Jessie and stretch same result
Sorry
Ok, it was just a thought. There have been a few issues where stretch breaks things. I don’t use spotify on my Pirate radio so I can’t be of much more help.
I’ve got the exact same issue, running Stretch Lite, as suggested by the setup guides.
