Introduction: “Rock, paper, scissors, Spock, lizard” is probably one of the most commons beginner’s Python program after “Hello world!”. I just took the one I had previously created and enabled the use of the Explorer HAT as a kind of game controller.
Background: I have always different projects in mind, I will use the Explorer HAT for creating a rover in the near future, I am also using my SenseHAT to log the environment, I am involved in the design of a gas sensing HAT and so on. I think the Explorer HAT has a lot of options so I started thinking about creating something with it and the game I heard about in Big Bang Theory came to my mind. Credits go to Sam Kass and Karen Bryla for creating the original game. The code is as follows:
#!/usr/bin/env python
#-*-coding:utf-8-*-
print("""
This program turns your Explorer HAT into a rock, paper, scissors, Spock, lizard playing machine!
Created by Iker García.
Hit touch pad 1 to select rock.
Hit touch pad 2 to select Spock.
Hit touch pad 3 to select paper.
Hit touch pad 4 to select lizard.
Hit touch pad 5 to select scissors.
Press CTRL+C to exit.
import explorerhat
import random
choices = ["rock", "Spock", "paper", "lizard", "scissors"]
player = 0
RaspberryPi = 0
result = 0
score = 0
def choice(ch, evt):
global choices #Define variables as global.
global player
global RaspberryPi
global result
global score
if ch < 6: #We are only going to use the first five touch pads.
if evt == 'press':
player = ch-1 #Saves player choice as a number, to calculate the result.
print("Player chooses: %s." % choices[ch-1]) #Prints our choice.
else:
print("Incorrect choice\n")
return
RaspberryPi = random.randrange(0,5)
print("Raspberry Pi is thinking...")
time.sleep(2) #Added to pretend that the Raspberry Pi is taking this game seriously.
print("Raspberry Pi chooses: %s." % choices[RaspberryPi]) #Prints Raspberry Pi's choice.
result = player - RaspberryPi #Calculates the winner.
if result == 0:
score += 0 #Updates the score
print("Player and Raspberry Pie tie!")
print("Score: %d\n" % score)
elif result % 5 < 3:
score += 1
print("Player wins!")
else:
score -= 1
print("Raspberry Pi wins")
try:
explorerhat.touch.pressed(choice) #Calls the function when a touch pad is presed.
except KeyboardInterrupt:
break
I think everything is explained in the same code, so you can see how it works. Anyway, you can ask whateveryou want. The name this time is RPSSL.
Here is the repo: https://github.com/IkerGarcia/RPSSL. Contributions are welcome!
Actually I am thinking that it would be a good idea to add a 16x2 LCD and a RGB LED matrix, to shine depending on the result.
Regards.
