[SOLVED] Skywriter (full-size) constantly detecting inputs
Hi there,
My fresh out-of-the-box Skywriter is having some problems.
When running the test.py example, I get constant inputs eventhough the Skywriter is just lying there with me far away from it (screenshot included)
It also barely registers flicks, but I assume this is due to the same problem.
Do you have any idea what might be causing this?
Thanks in advance
Screenshot of test.py output when left alone:
UPDATE: I have been advised by Pimoroni to return the Skywriter. I am assuming it is a faulty unit.
