Speakers producing static
My speakers producing nothing but static. Is there any way to fix this? Thanks.
EDIT: Maybe this would work?
Most people fix this by simply unplugging and re-attaching both sides of the cable.
Others have purchased a shielded 3.5mm cable.
I re-attached the speaker wires on the PCB and still the same.
Hi
Have you got any wires crossing the PCB near the speaker connector? I found that the amplifier IC is very susceptible to interference from the wiring to the switches. Once I ensured that no wires crossed this area of the PCB and I used a shielded cable the hissing/static disappeared.
Cheers
Paul
Thank you I’ll have to try that as I know that it is very crowded inside my Picade haha.
Ok so I got the sound working by swapping the red and black speaker wires + and - around.
