Hi!
dist is dietpi. raspberry pi zero w.
used install script curl -sS https://get.pimoroni.com/speakerphat | bash
nothing worked, ics was not enabled , enabled and rebooted
vmumeter works but no sounds is played and it throws errors
when running test.sh I get the following output:
./test.sh
testing audio
speaker-test 1.0.28
Playback device is default
Stream parameters are 48000Hz, S16_LE, 2 channels
WAV file(s)
ALSA lib pcm_direct.c:1539:(_snd_pcm_direct_get_slave_ipc_offset) Invalid value for card
Playback open error: -2,No such file or directory
testing basic wav playback
aplay: main:722: audio open error: No such file or directory
testing text-to-speech
ALSA lib confmisc.c:768:(parse_card) cannot find card '0’
ALSA lib conf.c:4259:(_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory
ALSA lib confmisc.c:392:(snd_func_concat) error evaluating strings
ALSA lib conf.c:4259:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
ALSA lib confmisc.c:1251:(snd_func_refer) error evaluating name
ALSA lib conf.c:4259:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:4738:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM sysdefault
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround21
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround40
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround41
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround50
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround71
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.iec958
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pcm_hw.c:1667:(_snd_pcm_hw_open) Invalid value for card
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM dmix
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
wave_open_sound > Pa_OpenStream : err=-9996 (Invalid device)
testing VU meter
root@DietPi:/home/dietpi/Pimoroni/speakerphat/test#
not sure where to go from here , I get similar results with speaker-test
speaker-test
speaker-test 1.0.28
Stream parameters are 48000Hz, S16_LE, 1 channels
Using 16 octaves of pink noise
any ideas , im a bit stuck now.
