what I will try to do though is to make it possible to check and re-attempt auth/login info at the end of the process, when the default values remain.
Thanks for this @lololo - Iād read this thread several times before I noticed this. I needed to follow that link, authenticate with Spotify and then copy the two keys (which populate after I logged in) to my mopidy.conf file.
Hi all,
I just found and followed this script
https://learn.pimoroni.com/tutorial/sandyj/streaming-spotify-to-your-pi
And tried with no luck to install on my pi3 which is running different web server (Home Assistant, Caddy, Etc).
But after reboot if I try to connect to Iris nothing happens.
Is pi3 compatible?
Thank you in advance
Iām having no luck getting this to work on my Pi2 - admittedly Iām not using Stretch Lite, Iām using full Stretch because I need a gui for this project. I can see Iris on the Pi itself at 127.0.0.1:6680/iris and even browse my own Spotify playlists but when I click on a track to play nothing happens and the Iris config page says the server then disconnects and Spotify disconnects. I added my credentials (user name, password and the 2 other keys) to both config files. Spent a stupid amount of time on this, I think I will give up :(
Tried a clean install of Stretch Lite and no luck either. My Pi is on the network, can see the internet, cannot browse to it at http://192.168.1.85:6680/iris - just get āconnection refusedā (IP address is correct, confirmed with ifconfig and my wifi router).
Thanks to @AllynH I finally got it working, but the web server seems a bit flaky. Sometimes it dishes up pages, sometimes it doesnāt and needs a reboot. I had to add the client ID and client secret from https://www.mopidy.com/authenticate/ to /etc/mopidy/mopidy.conf - the other /.config/ config file was missing.
Audio was a bit quiet out of the analogue jack, I had to over-ride it in alsamixer
Next task: having got it to work, I will break it by adding a GUIā¦
Hi, Sorry to come back to an old thread, but i am getting this problem.
iāve followed the instructions on the website. (ran the curl bash script) authorised the account and entered the details into the mopify.conf file but i am still not getting anything when i go to the url for iris.
iām using a pi zero w with full rapsbian stretch (for some reason i have a separate issue where i canāt connect to the wifi with the lite version).
iāve attempted to do all the of the fixes that work for other people but nothing seems to be working. iām not a pro and not proficient at debugging.
thanks in Advance.
James
