Photographs to follow:
Ingredients
a 7.5cm * 7.5cm box frame from HobbyCraft (http://www.hobbycraft.co.uk/innova-black-box-frame-75-x-75-cm/605218-1000) (currently £2)
a Unicorn Hat
a PiZero with a gpio connector installed + shim and WiFi dongle (for non Zero W)
a Pibow (this is optional but it does protect the pi and the electrical contacts)
layers of diffuser material (which can be carefully cut from a plastic milk bottle … of course if you live in South Staffordshire (and environs) Mountain Ash Crafts at Halfpenny Green Vinyard sell A4 sheets of diffuser material)
power pack
ten. use cool melt ‘hot’ glue to fix the Unicorn Hat in position
11. put Pi Zero in PiBow (note that the top clear layer now goes on the bottom otherwise the gpio pins won’t go in the hat connector) *don’t forget the microSD card (with software installed and configured so you can SSH in)
12. connect the Pi and hat
13. replace the back into the frame and bend the clips down
Now the last time I went to Mountain Ash Crafts they didn’t have the plastic diffuser sheet I used. What they did have was parchment paper with a much smoother texture at 20p an A4 sheet.
I also found parchment paper suitable for use as a chistmas diffuser!!
Unicorn Hat In a Frame … The Movie
