# Adding a bigger display to Enviro+
**URL:** <https://forums.pimoroni.com/t/adding-a-bigger-display-to-enviro/20671>\
**Category:** Raspberry Pi\
**Created:** [November 6, 2022, 3:03pm UTC](https://forums.pimoroni.com/t/adding-a-bigger-display-to-enviro/20671 "2022-11-06T15:03:47Z")\
**Showing post:** 12
**Post date:** [November 16, 2022, 10:23pm UTC](https://forums.pimoroni.com/t/adding-a-bigger-display-to-enviro/20671/12 "2022-11-16T22:23:00Z")
A lot of my code is modified Pimoroni examples. It’s where I unusually start.
That project evolved into a Pi Pico setup with two Pico Display Pack V2’s.
[Pi Pico based Weather Station Project - Discussion / Projects - Pimoroni Buccaneers](https://forums.pimoroni.com/t/pi-pico-based-weather-station-project/19503)
The same could be done with two Pi Display Hat Mini’s. And as near as I can tell, you could use a Pico Display Pack with a Pi and vis versa. They both use 3V logic and the same driver chips.
I have plans to wire up a Pico Display Pack to a Pi, just have to find my round 2it. ;)
I have one of the original 240 x 135 Display Packs sitting there doing nothing. It’s my replacement for the Enviro’s 160 x 80 LCD. It’s close to the same width versus height ratio.
I’ll likely use something like this to mate the two.
[Adafruit Perma-Proto 40-Pin Raspberry Pi Breadboard PCB Kit - with 2x2 - Pimoroni](https://shop.pimoroni.com/products/adafruit-perma-proto-40-pin-raspberry-pi-breadboard-pcb-kit-with-2x20-header?variant=29498828095571)
It’s what I did here, it’s running Enviro+ code. It’s 3 displays instead of just one.
 ![Front View](https://us1.discourse-cdn.com/flex016/uploads/pimoroni/original/2X/1/19072f67af206b8897b6a1910486dcb330a49abb.jpeg)
I thought I had a thread on this but can’t find it?
_[View the full topic](https://forums.pimoroni.com/t/adding-a-bigger-display-to-enviro/20671)._
