Broken inductor on EMF Explorer Badge Soldering Kit
I assembled a second EMF Explorer Badge last week, here’s my Adding sound-triggered LEDs to EMF Explorer Badgemy first one.
One of the audio channels wasn’t working on the headphones and I assumed it was the connector and filed a support ticket. I did some more thorough and methodical troubleshooting and to my surprise there was actually no signal to amplify, one of the inductors was broken. I desoldered it and sure enough it has infinite resistance. I couldn’t work out how to update the first ticket so I created a second ticket.
I don’t know how easy these are to destroy with heat but I’ve soldered four of these now and only one is broken. It seems likely the one I soldered that didn’t work was already broken or had a flaw. On all four I have soldered the leads down too (PCB is designed for this), this gives them more exposure to heat from the soldering process.
Is there any chance of getting a replacement inductor? Ideally I would like 5 rather than 1 so I can do some timed soldering tests with extended heating to see how robust these are. I’ll publish the results for the benefit of other constructors.
And do you know the manufacturer / part number for these?
There are some easily available Bourns ones that look similar but are slightly larger and have lower resistance, 207 and 208 ohms in my case. Perhaps I wasn’t paying attention when I bought 10 of those, the ones I got have leads that are about 1mm too far apart and too short to solder through the holes but they solder well onto the tracks if you give them a tiny bend inwards.
I desoldered the original working partner inductor slowly to give it a lot of heat as a test. That still works and measures 340 ohms which matches the other ones measured in-circuit at 328 and 348. Just to be thorough I’ve resoldered that onto a pcb leaving the iron on it for longer than I normally would and it still works.The inductors resistance goes up a bit when they are still hot from the soldering, it was at 400 ohms and is now 355 after about two minutes and still falling. My conclusion so far is the ones in the kit appear to be resilient to heat even from extended soldering.
