I’ve installed a new camera on my Pi Zero and when I run raspistill I get an error?
Note; I have enable the camera using raspi-config.
pi@raspberrypi:~/Documents/projects/zeroborg $ raspistill -o output.jpg
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn’t be enabled
mmal: main: Failed to create camera component
mmal: Failed to run camera app. Please check for firmware updates
I did a firmware update and “raspistill -o output.jpg” is working now. (I did think firmware updates under Raspian were handle by the commands below
sudo apt-get update
sudo apt-get upgrade
I’ve done an explicit “sudo rpi-update” now and “raspistill -o output.jpg” works but when I try and run a video test I get an error as below:
pi@raspberrypi:~/Documents/projects/zeroborg $ python testcam.py mmal: mmal_vc_port_enable: failed to enable port vc.null_sink:in:0(OPQV): ENOSPC mmal: mmal_port_enable: failed to enable connected port (vc.null_sink:in:0(OPQV))0xce6ee0 (ENOSPC) mmal: mmal_connection_enable: output port couldn’t be enabled Traceback (most recent call last):
_ File “testcam.py”, line 4, in _
_ camera = PiCamera()_
_ File “/usr/lib/python2.7/dist-packages/picamera/camera.py”, line 417, in init_
_ self.init_preview()
_ File “/usr/lib/python2.7/dist-packages/picamera/camera.py”, line 496, in init_preview
_ self, self.camera.outputs[self.CAMERA_PREVIEW_PORT])
_ File “/usr/lib/python2.7/dist-packages/picamera/renderers.py”, line 512, in init_
_ self.renderer.connect(source)_
_ File “/usr/lib/python2.7/dist-packages/picamera/mmalobj.py”, line 1467, in connect_
_ self.connection = MMALConnection(source, self.inputs[0])
_ File “/usr/lib/python2.7/dist-packages/picamera/mmalobj.py”, line 1280, in init_
_ prefix=“Failed to enable connection”)_
_ File “/usr/lib/python2.7/dist-packages/picamera/exc.py”, line 157, in mmal_check_
_ raise PiCameraMMALError(status, prefix)_ picamera.exc.PiCameraMMALError: Failed to enable connection: Out of resources (other than memory)
testcam.py
from picamera import PiCamera
from time import sleep
It might be your memory split, can you fire up the Raspberry Pi Configuration tool from the menu and see what’s set?
You can also use raspi-config at the terminal.
You shouldn’t ever need to do this, it subverts the normal upgrade process, installing pre-release software and can easily cause more problems than it solves.
This problem only occur in camera raspberry pi V2.1 (IMX219) from Element14 . But in camera raspberry pi V2.1 from OKdo , i don’t get this error
So, the solution when error
“mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: Failed to run camera app. Please check for firmware updates”
You need some initialization with a works camera (me camera from OKdo ).
So, the step is 1. Plug your works camera to Raspberry Pi (me using Raspberry Pi 4B) 2. Turn on your Raspberry Pi 3. check "
vcgencmd get_camera
to make sure your hardware is detected the camera 4. capture image using
raspistill -v
and camera will capture the image 5. Then replace the works camera with ENOSPC Error Camera (from Element14 ) 6. then try to capture the image
raspistill -v
and the ENOSPC Error will not occur
Notes:
But, after the ENOSPC Error Camera works, and then you restart/shutdown the raspberry pi, the error will occur again :(
OS Raspberry Pi 4 Model B (4GB)
Linux raspberrypi 5.10.60-v7l+ #1449 SMP Wed Aug 25 15:00:44 BST 2021 armv7l GNU/Linux
