Converting a cold war signal light to batterys
Hi there, I was wondering how to go about converting this old Cold War signal light back to battery for my friend. He bought it already working with a mains wiring that converts the 240v AC to 12V max 10W
I’d like it to be a simple rechargeable system that will be able to operate for over 1 hour so it will need at least 2000mAh I think.
I’ve not done anything involving using battery supplies before, so I would apreseate some advice on how I set up a system that can also be recharged easily (maybe by USB?)
thanks.
this is the current converter that is wired in
Google for 12V rechargeable batteries. There are many options available (e.g. solid lead-acid blocks, LiPo-type batteries, LiFePO4), some of them come together with chargers. Be aware that batteries that have a 12V label never provide 12V (voltage drops during discharge like with any battery), so if you really need these 12V you would also have to think about a boost-converter that gives you stable 12V.
