Here is a handy utility I wrote - the main intent is being able to set the FanShim LED colour from the command line.
You can then set colours from inside a long running script, maybe an overnight build, and signal results by the LED colour.
Just create a file ‘fanShimSet’ with this code and chmod 755
#!/usr/bin/env python3
#fanShimSet - a simple way to set the fan and LED colour on the Pimoroni FanShim
#(c)2019 Kym Farnik - free to use
#requires the Pimoroni FanShim software to be installed as well as 'sudo pip3 install colour'
# from https://github.com/pimoroni/fanshim-python
#useful in long running scripts to use the LED to report progress
#Color=US spelling
#Colour=the rest of the english speaking world
from fanshim import FanShim
import sys
import plasma
import argparse
import re
from colour import Color, COLOR_NAME_TO_RGB
def str2bool(val): #function to parse/normalaise the --fan -f setting to True/False
if val.lower() in ('yes', 'true', 't', 'y', '1', 'on'):
return True
elif val.lower() in ('no', 'false', 'f', 'n', '0', 'off'):
return False
else:
raise argparse.ArgumentTypeError('Boolean value expected.')
parser = argparse.ArgumentParser(description='Sets the LED colour on the Pimoroni FanShim')
parser.add_argument('--listcolors', '-l', help="List all color words", action="store_true")
parser.add_argument('--color', '-c', default='notset', help="Color is a hex string or color name '#RRGGBB' eg. -c=#0000FF or -c White etc.")
parser.add_argument('--fan', '-f', type=str2bool, nargs='?', const=True, default=True, help="Fan On/Off (True/False) default True.")
parser.add_argument('--verbose', '-v', help="verbose actions", action="store_true")
args = parser.parse_args()
carg = args.color.lower() #hex color #...... (or word)
match = re.search(r'^#(?:[0-9a-fA-F]{6})$', carg)
if match:
r,g,b = (int(carg[i:i+2], 16) for i in (1, 3, 5))
elif carg in COLOR_NAME_TO_RGB:
r,g,b = COLOR_NAME_TO_RGB[carg]
elif carg == 'notset':
pass
else:
print("Color is not valid, must be '#RRGGBB' format or name, eg. -c=#2257AC or --color '#aaff60' or -c Blue")
sys.exit(1)
if args.listcolors:
for cname in COLOR_NAME_TO_RGB.keys():
rgb = COLOR_NAME_TO_RGB[cname]
hc = Color(cname)
print(cname.capitalize(), "RGB:", rgb, "HEX:", hc.hex_l)
#now make it all happen...
fanshim = FanShim()
plasma.set_clear_on_exit(False) #this MUST be set False otherwise the led turns off on exit
if args.fan:
fanshim.set_fan(True) #fan on (keep it cool)
if args.verbose:
print("Fan is set on")
else:
fanshim.set_fan(False) #fan off
if args.verbose:
print('Warning: Fan is OFF, watch the temperature')
if carg != 'notset':
fanshim.set_light(r, g, b) #set color
if args.verbose:
chex = '#%02x%02x%02x' % (r, g, b)
print("Color is set to RGB:", r, g, b, 'HEX:', chex)
sys.exit(0)
