Get hyperpixel to work in PINN bootloader
hi guys so still a bit unsure on getting the hyperpixel 4.0 to run in the pinn bootloader and could use a little help , so i need to go to the pinn recovery directory and create a script /mount that will run the hyperpixel4-init code
like
sudo nano /tmp/media/pinn_init.sh (file name pinn wants in recovery partition)
add the hyperpixel4-init code
#!/bin/bash
SERVICE_NAME=“hyperpixel4-init.service”
SERVICE_PATH="/etc/systemd/system"
BINARY_NAME=“hyperpixel4-init”
BINARY_PATH="/usr/bin"
OVERLAY_PATH="/boot/overlays"
OVERLAY_NAME=“hyperpixel4.dtbo”
CONFIG="/boot/config.txt"
CONFIG_LINES=(
“dtoverlay=hyperpixel4”
“overscan_left=0”
“overscan_right=0”
“overscan_top=0”
“overscan_bottom=0”
“framebuffer_width=800”
“framebuffer_height=480”
“enable_dpi_lcd=1”
“display_default_lcd=1”
“dpi_group=2”
“dpi_mode=87”
“dpi_output_format=0x7f216”
“display_rotate=3”
“hdmi_timings=480 0 10 16 59 800 0 15 113 15 0 0 0 60 0 32000000 6”
if [ $(id -u) -ne 0 ]; then
printf “Script must be run as root. Try ‘sudo ./install.sh’\n”
exit 1
fi
if [ -d “$SERVICE_PATH” ]; then
cp dist/$BINARY_NAME $BINARY_PATH
cp dist/$SERVICE_NAME $SERVICE_PATH
systemctl daemon-reload
systemctl enable $SERVICE_NAME
systemctl start $SERVICE_NAME
printf “Installed: $BINARY_PATH/$BINARY_NAME\n”
printf “Installed: $SERVICE_PATH/$SERVICE_NAME\n”
else
printf “Warning: cannot find $SERVICE_PATH for $SERVICE_NAME\n”
fi
if [ -d “$OVERLAY_PATH” ]; then
cp dist/$OVERLAY_NAME $OVERLAY_PATH
printf “Installed: $OVERLAY_PATH/$OVERLAY_NAME\n”
else
printf “Warning: unable to copy $OVERLAY_NAME to $OVERLAY_PATH\n”
fi
if [ -f “CONFIG" ]; then for ((i = 0; i < {#CONFIG_LINES[@]}; i++)); do
CONFIG_LINE=”${CONFIG_LINES[$i]}"
grep -e “^#$CONFIG_LINE” CONFIG > /dev/null STATUS=?
if [ $STATUS -eq 1 ]; then
grep -e “^$CONFIG_LINE” CONFIG > /dev/null STATUS=?
Line is missing from config file
echo “$CONFIG_LINE” >> $CONFIG
printf “Config: Added $CONFIG_LINE to $CONFIG\n”
else
printf “Skipped: $CONFIG_LINE already exists in $CONFIG\n”
fi
else
sed $CONFIG -i e “s/^#$CONFIG_LINE/$CONFIG_LINE/”
printf “Config: Uncommented $CONFIG_LINE in $CONFIG\n”
fi
done
else
printf “Warning: unable to find $CONFIG, is /boot not mounted?\n”
printf “Please add $OVERLAY_CONFIG to your config.txt\n”
fi
cntrl + X to save
how do i mount this in the pinn recovery directory , love the screen trying to make more portable :)
I’m having no luck getting PINN to initialise HyperPixel4 correctly.
They even ship files to support the original HyperPixel, and using the same technique results in nada, nothing, zip, zero :(
https://sourceforge.net/projects/pinn/files/
YMMV but it looks like you should be able to extract hyperpixel-display.zip over your PINN recovery partition when you first create the SD card on a host computer and replace the hyperpixel-init binary with the hyperpixel4-init from the HyperPixel4 GitHub - being careful to rename it to hyperpixel-init so it’s called by pinn_init.sh.
Still, it wont work for me and I can’t figure out why. It’s hard to debug with no screen and no UART!
Might be worth raising an issue on the PINN GitHub: https://github.com/procount/pinn
Thank you for trying , do you know if the hyperpixel will work with the noobs bootloader I really don’t have a preference between the too
Sadly not. Although you can still boot into one OS and then reboot to see the bootloader on the screen IIRC (as long as NOOBs config.txt is set up correctly I suspect).
Procount/PINN was able to get the hyperpixel 4.0 working with PINN bootloader and bow has added the code into the PINN installer on sourceforge for anyone who reads this post
Now not bow I hate autocorrect
