# How-to: Picade 12" Screen + HAT + Single Power Source + On/Off Buttons!
**URL:** <https://forums.pimoroni.com/t/how-to-picade-12-screen-hat-single-power-source-on-off-buttons/3922>\
**Category:** Picade\
**Created:** [February 2, 2017, 9:36pm UTC](https://forums.pimoroni.com/t/how-to-picade-12-screen-hat-single-power-source-on-off-buttons/3922 "2017-02-02T21:36:43Z")\
**Showing post:** 28
**Author:** ![fcalcada](https://avatars.discourse-cdn.com/v4/letter/f/f9ae1b/32.png) [@fcalcada](https://forums.pimoroni.com/u/fcalcada)\
**Post date:** [May 19, 2017, 4:36pm UTC](https://forums.pimoroni.com/t/how-to-picade-12-screen-hat-single-power-source-on-off-buttons/3922/28 "2017-05-19T16:36:41Z")
Hey.
Seems you have some questions like I had in the beginning. but this topic has (almost) all the answers.
You mayneed to by a 12v barrel jack cable with only a male plug to branch out the 12v coming in and going into the LCD Driver board. something like this:
[http://www.ebay.com/itm/10pcs-Surveillance-CCTV-Camera-DC-12V-Power-Cable-Male-Connector-/110759673207](http://www.ebay.com/itm/10pcs-Surveillance-CCTV-Camera-DC-12V-Power-Cable-Male-Connector-/110759673207)
The jumper cables going from the ATXRaspi to the Raspberry (to send shutdown/boot signals) as per LowPowerLabs recommendation should be good quality to avoid problems, and if powering Pi via GPIO from ATXRaspi, you should also use high grade jumper wires.
depending on the power source you select, your female dv jack in should match the power source. most say the plug is either 5.5mmx2.1mm or 5.1mmx2.1mm so you should get a female jack panel mount that matches. something like this:
> **[10 x 2.1mm x 5.5mm Round Panel Chasis Mount Female: Amazon.co.uk: Electronics](https://www.amazon.co.uk/d/DC-Connectors/2-1mm-Chasis-Female-Socket-Connector/B00WZ83FK2/)**
> Pack of 10 DC female sockets. The sockets are suitable for 2.1mm x 5.5mm male plugs with a 9mm barrel length. The sockets have 2 pins and require a 8mm panel hole diameter.
You then onlu need to drill 2 small holes on the back panel of the Picade, one to fit the switch, another to fit the dc socket.
As for artwork, try and have a look at this topic:
[http://forums.pimoroni.com/t/new-artwork-for-picade-cabinet/2618/278](http://forums.pimoroni.com/t/new-artwork-for-picade-cabinet/2618/278)
Hope this helps (and that I got it right) and dont forget to post pics of your completed setup :)
_[View the full topic](https://forums.pimoroni.com/t/how-to-picade-12-screen-hat-single-power-source-on-off-buttons/3922)._
