HyperPixel 4.0 Square not working
Hello,
I am trying to get my HyperPixel Square (bought in 2020) to work on my Pi4 model B. It used to work but shows some vertical lines (photo). No reason to think the screen suffered physical damage. Touch capabilities are still working.
Just booted on the latest Raspberry Pi OS version flashed on SD.
I installed the screen as Pimoroni recommends and tried legacy drivers as described in previous posts, but no luck.
Any ideas?
Thank you
Which Raspberry Pi OS image date and kernel version are you using, and which display overlay lines are currently in your boot configuration? Pimoroni’s hyperpixel4 README distinguishes the built-in support in newer OS images from the legacy drivers kept for pre-2021 Square units. Since yours was bought in 2020, I would clarify that combination before recommending either driver route. Please paste only the display-related configuration lines, not the whole file.
Hello,
I flashed the latest version, via pi imager, Trixie, kernel 6.18
The line I put in is on config.txt
dtoverlay=vc4-kms-dpi-hyperpixel4sq
thank you
Thanks, that clarifies the software side. Pimoroni’s hyperpixel4 repository has a separate square-pi4 branch explicitly labelled for Pi 4/400 with Square boards manufactured in 2020 or earlier. Issue 177 also discusses an early Square revision that needs initialisation not provided by the newer overlay, which may be relevant to your 2020 purchase. I would confirm your board revision and a supported OS/driver combination with Pimoroni before reinstalling: the legacy driver is unmaintained, and these notes do not establish that it works on Trixie.
thank you
Basically quickest solution would be to buy a new screen?
I would not buy a replacement on this evidence alone. The Pimoroni comment about the early revision is from 2023, so it does not establish what works with Trixie today. Before spending anything, ask Pimoroni to confirm both whether your existing board has a supported driver option and which currently sold revision they support on a Pi 4 with your OS. A newer screen may be an option, but I cannot confirm it is the quickest fix for your setup.
