I have picoreplayer setup with a HyperPixel 4.0 touch display and a rasberry zero (first generation). As the CPU performance is sometime creating sound issues, I decided to switch to a zero 2.
The display is working fine but the the toch functionality is gone. Has someone made a similar experience when switching from zero 1 to zero 2?
? - I dont have an answer ,just a question ,based on some of my own issues over the yrs ! , did you just switch sdcard to the 2 ,or did you create a new setup on the zero 2 ,good luck
Hello Caperjack1953 - I haven’t created a new setup but just moved the sdcard from the old raspberry zero to the zero 2. The old config was quite time consuming so I was hoping that it would work plug and play…
might be your issue ,just from my own experience things don’t always go the way we would like it too. I’m not the most experienced person here ,so you can wait to see if anyone else chimes in ! Good luck
