# Hyperpixel 4.0 - touch not working
**URL:** <https://forums.pimoroni.com/t/hyperpixel-4-0-touch-not-working/8185>\
**Created:** [July 20, 2018, 9:20pm UTC](https://forums.pimoroni.com/t/hyperpixel-4-0-touch-not-working/8185 "2018-07-20T21:20:22Z")\
**Showing post:** 4
**Author:** ![monglet](https://sea2.discourse-cdn.com/flex016/user_avatar/forums.pimoroni.com/monglet/32/1113_2.png) [@monglet](https://forums.pimoroni.com/u/monglet)\
**Post date:** [July 21, 2018, 6:19am UTC](https://forums.pimoroni.com/t/hyperpixel-4-0-touch-not-working/8185/4 "2018-07-21T06:19:20Z")
Ah ok.
Followed this from gadgetoid:
> [@Hyperpixel 4.0 Touchscreen Rotate with Display](https://forums.pimoroni.com/t/hyperpixel-4-0-touchscreen-rotate-with-display/8172/8):
> What happens if you; grab the latest source from GitHub, go into the “src” directory and type “Make” to build your own dtbo file Copy that hyperpixel4.dtbo into /boot/overlays Reboot There’s nothing in the new overlay source that should cause the touchscreen to not work, but I wonder if I’ve somehow built a dodgy dtbo. Even then, I’d expect nothing to work. Odd! Edit: I have a suspicion that the older system I compiled the dtoverlay on might be sufficiently different to the latest Raspbian t…
Back up and running. And rotated!
_[View the full topic](https://forums.pimoroni.com/t/hyperpixel-4-0-touch-not-working/8185)._
