HyperPixel 4.0 - VNC screen resolution setting?
Is there a way to change (increase) the resolution of the (shared/virtual) screen I see on my mac when using VNC?
The resolution in config.txt is set to the correct resolution for the HyPix screen(800x480), but I’d rather a larger display when I log in from my mac…
Can this EVEN be DONE!!!???
Thanks.
I would say thats done in VNC, and should be doable.
https://www.bing.com/search?q=VNC+screen+size&form=EDGNB2&mkt=en-ca&httpsmsn=1&plvar=0&refig=cc6ddd2afc324e52ec3a4f5faf8d53da&sp=-1&pq=vnc+screen+si&sc=0-13&qs=n&sk=&cvid=cc6ddd2afc324e52ec3a4f5faf8d53da
@Tim_Allan_UK You can set the resolution if you use a virtual vnc connection.
https://www.realvnc.com/en/connect/docs/raspberry-pi.html
I’ve been trying to change the resolution on the “real” vnc connection but it seems to be stuck at the HP4.0 resolution. :(
Edit
You can change the framebuffer_width and framebuffer_height in your boot/config.txt file to manually set the resolution of the hyperpixel. This will change the resolution of your VNC connection and it willchange the resolution of the GUI on your hyperpixel.
@mydudechris, thanks, I’ll give that a go!
Hi there
Reading this thread I was able of changing VNC and screen resolution, but can anyone point me to a good resolution that fully covers screen (I hate black bands but I want to work at my remote computer)
This is my config.txt file
framebuffer_width=1920
framebuffer_height=1080
#uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
#uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=2
#hdmi_mode=82
