Hyperpixel4 Black screen, touch working
Heya!
I have been trying to get my hyperpixel4 weirdly square screen working for about a week now,
I have tried multiple sd-cards, powersupplies and even another screen.
I install a fresh raspberrypi os (32 bit)
Run trough the setup, update the pi and reboot.
After that i have tried running the one line installer but also the getting the specific branch and installing from there.
Sadly whatever i do when i reboot the pi it starts with a blanc command line (only a flickering "_"in the top right) followed by a Welcome to the raspberry pi os desktop screen.
After that its turns black.
I did however find that the touchscreen seems to work as i can see the mouse moving when i open the pi-os using vnc
doing Systemctl enable hyperpixel4-init
gives me the following message: Failed to enable unit: Unit file hyperpixel4-init.service does not exist.
I am trying to do this on a raspberry pi zero W
Hope you guys can help me.
Any advice is welcome!
Platform Information
Revision : 9000c1
Description: Raspbian GNU/Linux 11 (bullseye)
5.10.63+
Touchscreen logs
Rectangular: Goodix
Square: ft5
[ 46.563546] edt_ft5x06 11-0048: supply vcc not found, using dummy regulator
[ 46.581593] input: generic ft5x06 (11) as /devices/platform/i2c@0/i2c-11/11-0048/input/input2
I2C Devices and Mappings
/dev/i2c-11
/dev/i2c-2
Error: Could not open file /dev/i2c-1' or /dev/i2c/1’: No such file or directory
Boot Config
For more options and information see
Raspberry Pi Documentation - Configuration
Some settings may impact device functionality. See link above for details
uncomment if you get no picture on HDMI for a default “safe” mode
#hdmi_safe=1
uncomment the following to adjust overscan. Use positive numbers if console
goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
uncomment to force a console size. By default it will be display’s size minus
overscan.
#framebuffer_width=1280
#framebuffer_height=720
uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
uncomment to force a HDMI mode rather than DVI. This can make audio work in
DMT (computer monitor) modes
#hdmi_drive=2
uncomment to increase signal to HDMI, if you have interference, blanking, or
no display
#config_hdmi_boost=4
uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
Uncomment some or all of these to enable the optional hardware interfaces
dtparam=i2c_arm=off
#dtparam=i2s=on
dtparam=spi=off
Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
Additional overlays and parameters are documented /boot/overlays/README
Enable audio (loads snd_bcm2835)
dtparam=audio=on
Automatically load overlays for detected cameras
camera_auto_detect=1
Automatically load overlays for detected DSI displays
display_auto_detect=1
Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
Disable compensation for displays with overscan
disable_overscan=1
[cm4]
Enable host mode on the 2711 built-in XHCI USB controller.
This line should be removed if the legacy DWC2 controller is required
(e.g. for USB device mode) or if USB support is not required.
otg_mode=1
[all]
[pi4]
Run as fast as firmware / board allows
arm_boost=1
[all]
dtoverlay=hyperpixel4
enable_dpi_lcd=1
dpi_group=2
dpi_mode=87
dpi_output_format=0x5f026
dpi_timings=720 0 20 20 40 720 0 15 15 15 0 0 0 60 0 36720000 4
Try Buster instead of Bullseye. You can get it here under Raspberry Pi OS (Legacy) if you don’t have it.
Operating system images – Raspberry Pi
The Pi imager will also give to you if you select “Raspberry Pi OS Other” and scroll down the list.
