LDR Motor control
HI everyone
I am try to stop and start a motor with an ldr I have written the following code.
import explorerhat
def play(channel, event):
if channel > 1:
return
if event == ‘press’:
explorerhat.motor.one.forwards(50)
if event == ‘release’:
explorerhat.touch.one.pressed(play)
explorerhat.touch.one.released(play)
level = explorerhat.analog.one.read()
for i in range(0, 4):
if level > float(i + 1):
explorerhat.motor.one.stop()
time.sleep(15)
time.sleep(20)
print(level)
time.sleep(0.25)
I would like the motor to stop for 15 sec when the light is on the ldr and then start again. The led light is in front of the ldr always and the motor moves the light blocking object in front of the ldr.
