# Need help with some Unicorn HD code, display color issue
**URL:** <https://forums.pimoroni.com/t/need-help-with-some-unicorn-hd-code-display-color-issue/14399>\
**Created:** [June 30, 2020, 3:26pm UTC](https://forums.pimoroni.com/t/need-help-with-some-unicorn-hd-code-display-color-issue/14399 "2020-06-30T15:26:49Z")\
**Showing post:** 7
**Post date:** [June 30, 2020, 7:17pm UTC](https://forums.pimoroni.com/t/need-help-with-some-unicorn-hd-code-display-color-issue/14399/7 "2020-06-30T19:17:32Z")
Actually its not a big deal as I am going to want to add more messages. Each one showing in order one after the other, and I am going to want to change my text color on the fly. I’ll be setting it in the while true section anyway.
I have working code for the Unicorn Mini just trying to switch to a Unicorn HD.
> [@Adjust Python examples](https://forums.pimoroni.com/t/adjust-python-examples/13954/96):
> The “and the Temperature is” displays as text. The %s displays what’s after the other % sign out side the brackets. % (T) displays the variable T which is the rounded off temperature. Taken from the BME280 T = bme280.get\_temperature() T = round(T) And the c (more text) to denote degrees Celsius. Have a look at this. This will work with a BME680 etc, with some code changes. #!/usr/bin/env python3 import sys import os import time, datetime import RPi.GPIO as GPIO from PIL import Image, Imag…
_[View the full topic](https://forums.pimoroni.com/t/need-help-with-some-unicorn-hd-code-display-color-issue/14399)._
