On off shim shutdown message
Is there any chance to change a broadcast message from root after pressing button to different one or ideally some graphic. Tried to look online but couldn’t find any solution
If you’re using cleanshutd it should broadcast a message using wall by default:
You may need to change the shutdown_delay in /etc/cleanshutd.conf to something other than 0 minutes though.
