Pi 5 + TEAM MP33 MAP1202 dies during idle despite HMB/APST/ASPM disabled
Hello, I’m looking for advice on the MAP1202 variant of the TEAM MP33, following the earlier MP33 discussion. The APST/ASPM workaround from that thread is already applied, but I still get controller disconnects.
Important distinction: my adapter came with the db-tronic Raspberry Pi kit (Amazon ASIN B0CRMQCYXH), not a confirmed Pimoroni NVMe Base. I’m asking here because of your MP33 testing and the experience in the linked thread. Its exact adapter model/revision is being checked with the kit supplier.
Setup
  • Raspberry Pi 5, db-tronic 8GB kit, supplied adapter/ribbon, official 27W Raspberry Pi supply.
  • TEAMGROUP MP33 1TB, part TM8FP6001T0C101; reported model TEAM TM8FP6001T; MAXIO MAP1202 controller (1e4b:1202 rev 01), firmware SN15527.
  • Raspberry Pi OS kernel 6.18.50+rpt-rpi-2712, package 1:6.18.50-1+rpt1 (11 September 2026).
  • Bootloader 66f33f7e651cf482a26fb2c931a7587bb14e71db (11 May 2026).
  • PCIe Gen2 x1. The application, database and root/boot filesystem are on a separate Crucial USB SSD. TEAM is only an isolated test/data drive.
Repeat failure on 3 November 2026
The TEAM passed substantial verified testing on 21–22 October, then stopped responding on 28 October. A controlled cold start restored it on 3 November. HMB was disabled from driver initialization: effective max_host_mem_size_mb=0, and NVMe feature 0x0d confirmed EHM disabled/HSIZE 0. Journal recovery and a full unmounted filesystem check then passed.
A 32GiB direct write followed by full CRC32C read verification passed (fio error 0). It then entered idle, still with administrative SMART polling every 30 seconds. First sampled idle was 14:37:01 GMT; last healthy sample 14:57:36. At 14:59:07 the kernel reported:
nvme nvme0: controller is down; will reset: CSTS=0xffffffff, PCI_STATUS=0x10
nvme nvme0: Disabling device after reset failure: -19
EXT4-fs (nvme0n1p1): shut down requested (2)
Aborting journal on device nvme0n1p1-8.
Last successful SMART sample: about 41°C (maximum sampled during the soak 54°C), critical_warning=0, media_errors=0, num_err_log_entries=0. Power cycles and unsafe shutdown counts did not increase during the test. Pi throttled=0x0.
These boot settings were already in force:
nvme.max_host_mem_size_mb=0 nvme_core.default_ps_max_latency_us=0 pcie_aspm=off pcie_port_pm=off
The root port’s post-failure PCI snapshot has a new BadTLP flag. The endpoint has UnsupReq+, AdvNonFatalErr+ and HeaderOF+. Software AER counters remain zero; error reporting enables were off in the PCI snapshot. The sticky bits do not reveal event order, so some could be effects of the kernel’s automatic reset. Configuration space remained readable, but the NVMe controller became dead. No manual resets/reprobe were attempted afterward; kernel journal and health snapshots are retained on USB.
Questions
  1. Does anyone have sustained experience with the MAP1202/SN15527 MP33 variant, especially idle disconnects after successful load tests? Was that controller/firmware variant included in the MP33 compatibility testing?
  2. Is there a confirmed kernel or drive-firmware fix matching this failure, beyond the power-saving workaround already applied?
  3. What read-only evidence would best distinguish controller firmware hang, PCIe link/adapter power trouble, and a host-driver issue?
I also found the same db-tronic kit discussed on Raspberry Pi Forums, where Gen1 and USB-dongle removal were changed together, and Geekworm’s MAP1202/Gen2 warning. Neither establishes a fix for this exact combination.
I need to keep the production Pi running after earlier storage failures and data loss. I’m not currently making further reboot/reset/formatting/firmware-flashing changes or moving the production drive. Advice on the captured evidence and known workarounds would be much appreciated. Thank you.
