I’m trying to setup a headless Raspberry Pi running Fluidsynth using the Piano Hat as the MIDI input. So far all of the examples work (I’m especially fond of the 8-bit synth) except for midi-piano. When I run it I get the following:
This script requires the midi module
Install with: sudo pip install midi
Following those directions results in:
Looking in indexes: Simple index, piwheels - Simple index
ERROR: Could not find a version that satisfies the requirement midi
ERROR: No matching distribution found for midi
Does anyone know where that module is? It’s such a common term I can’t find it myself.
Or, does anyone happen to know if I can’t actually use the Piano Hat that way?
Ok, that sucks. My Piano Hat is setup as an itty bitty beat box with a Drum Hat. Buster I think? It’s not Bullseye that’s for sure, might even be Jessie.
The only example I ran was the simple-piano.py as that’s the one used for the beat box setup.
I can get the local piano to work, as well as the 8-bit synth. Only the midi piano isn’t working.
Edit: Something I forgot. I tried following the Readme.md in the files but doing that not only doesn’t make midi-piano work, but after everything else stops working.
