Hello Pirate buddies,
Just wanted to share my experience by setting up Pirate Audio Headphone Amplifier. Some trials and errors.
-Reinstalled to new OS- Buster
-Installed Pimoroni Audio Software
Thanks to the old thread especially Alphanumeric solved 1.3 color tft LCD on btreakout garden pHat, SPI i2c - #12 by alphanumeric
- Enabled SPI
- sudo install pip3 st7789
First, I did typed sudo pip install st7789. It is for Python 2.7 and did not check on Raspi-configuration to see SPI is enabled or not. Then, set enabled SPI then type pip3 st7789. It works great. Tiny screen but crispy colors.
Oh, to add in config.txt . It is working to write in terminal command:
sudo nano /boot/config.txt
dtoverlay=hifiberry-dac, gpio=25=op,dh
change to
dtparam=audio=off from dtparam=audio=on
For some reason, I got a message “Permission denied” when I opened the folder /boot/config.txt in GUI. Terminal is the only way to allow me to edit or add the configuration.
Hope that helps
