PiTFT Case & RPi B rev 1
I notice that the PiTFT case claims to only fit the B rev 2 can the case and/or the Pi B rev 1 be modified to fit, maybe by cutting off the JTAG pins?
You will need to properly remove the JTAG header, and make sure that the solder on the top side is as flush as you can get it. There’s also a clash with the LEDs, so some careful shaving down of spars is required. Other than that, I haven’t had any problems (although mine isn’t being used with a PiTFT, but with the RGB LCD plate, using a couple of extra layers).
