Presto – Errors When Running Example Scripts
Hi All,
Some of the example scripts for Presto fail to run due to module import errors.
For instance:
• In “buzzer.py”, the line
from presto import Presto, Buzzer
results in:
ImportError: can’t import name ‘Buzzer’
• In “touch_buttons.py” , the line
from touch import Button
results in:
ImportError: can’t import name ‘Button’
Do I need to reflash the latest uf2 file to resolve this issue?
Where can I download the latest (or previous) uf2 files for Presto?
Or is it necessary to build the firmware manually?
Any advice would be greatly appreciated. Thanks in advance!
You need the latest uf2. I had that problem. It’s a good idea to keep these up to date when using a new board.
You can find v7 here:
Releases · pimoroni/presto
When working I found the buzzer to be very quiet.
Thank you very much for your help. I really appreciate it.
