Thanks, alphanumeric. My full program runs to more than 900 lines, but here is Tony’s original program with initialisation changes to suit the Plus 2 W and Display Pack 2.8, which still shows the problem for me:
# Pimoroni Explorer Demo
# Analog/ Digital clock - Tony Goodhew, Leicester UK - 6 Nov 2024
# Uses the Multi-Sensor Stick (BME280 + LTR559 + LSM6DS3)
#from explorer import display, i2c, button_z, button_x, button_y, BLACK, WHITE, GREEN, RED, BLUE, YELLOW, CYAN
from picographics import PicoGraphics, DISPLAY_PICO_DISPLAY_2, PEN_RGB565
from pimoroni import RGBLED
from machine import I2C
from breakout_bme280 import BreakoutBME280
from breakout_ltr559 import BreakoutLTR559
import math
display = PicoGraphics(display=DISPLAY_PICO_DISPLAY_2, pen_type=PEN_RGB565, rotate=0, layers=2)
display.set_font('bitmap8')
i2c = I2C()
GREEN = display.create_pen( 0, 255, 0)
RED = display.create_pen(255, 0, 0)
BLUE = display.create_pen( 0, 0, 255)
YELLOW = display.create_pen(255, 255, 0)
CYAN = display.create_pen( 0, 255, 255)
led = RGBLED(26, 27, 28)
led.set_rgb(0, 0, 0)
# Check sensor stick connected
try:
bme = BreakoutBME280(i2c, address=0x76)
ltr = BreakoutLTR559(i2c)
except RuntimeError:
display.set_layer(0)
display.set_pen(RED)
display.clear()
display.set_pen(WHITE)
display.text("Multi-Sensor Stick missing", 10, 95, 320, 3)
display.update()
# Get current time
year, month, day, h, m, s, wd, _ = time.localtime()
old_m = -1
days = ["Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday", "Sunday"]
months = ["Jan", "Feb", "Mar", "Apr", "May", "Jun", "Jul", "Aug", "Sep", "Oct", "Nov", "Dec"]
# Used for minute and hour hands
def hand(ang, long):
ang = ang-90
ls = long/10
x0 = int(round(long * math.cos(math.radians(ang))))+cx
y0 = int(round(long * math.sin(math.radians(ang))))+cy
x1 = int(round(ls * math.cos(math.radians(ang+90))))+cx
y1 = int(round(ls * math.sin(math.radians(ang+90))))+cy
x2 = int(round(ls * math.cos(math.radians(ang-90))))+cx
y2 = int(round(ls * math.sin(math.radians(ang-90))))+cy
display.triangle(x0,y0,x1,y1,x2,y2)
display.circle(cx,cy,int(ls))
display.set_backlight(1.0)
display.set_pen(BLACK)
display.clear()
display.set_layer(1)
display.clear()
cx = 199 # centre of clock
cy = 119
l = 110
# Draw clock face
display.set_pen(BLUE)
display.circle(cx,cy,110)
display.update()
ls = 94
for angle in range(0,360,6):
xx = int(round(l * math.cos(math.radians(angle))))
yy = int(round(l * math.sin(math.radians(angle))))
display.line(cx,cy,cx+xx,cy+yy)
display.circle(cx,cy,100)
for angle in range(0,360,30):
# Sensor titles
display.text("Temperature",5,40,310,1)
display.text("Lux",5,80,300,1)
display.text("Rel Humidity",5,120,300,1)
display.text("Air Pressure",5,200,300,1)
# === Main Loop ======
# Draw face numbers
display.circle(cx,cy,93) # Clear centre of clock face
display.set_pen(YELLOW)
display.text("9",118,108,320,3)
display.text("3",268,108,320,3)
display.text("10",128,70,320,3)
display.text("2",258,70,320,3)
display.text("1",230,45,320,3)
display.text("11",160,45,320,3)
display.text("12",190,37,320,3)
display.text("6",193,186,320,3)
display.text("7",156,176,320,3)
display.text("5",230,176,320,3)
display.text("4",258,150,320,3)
display.text("8",130,150,320,3)
# Draw hands
mang = int((m + s/60)* 6) # angle of minute hand
hang = int((h + m/60 )* 30 ) # angle of hour hand
hand(mang,90)
hand(hang,70)
sang = 6 * s - 90
xs = int(round(ls * math.cos(math.radians(sang))))
ys = int(round(ls * math.sin(math.radians(sang))))
display.line(cx,cy,cx+xs,cy+ys)
display.circle(cx,cy,3)
# Assemble Digital time
# dt = "%02d:%02d:%02d" % (h, m, s)
ss = "0" + str(s)
lgs =len(ss)
ss = ss[lgs-2:lgs]
ms = "0" + str(m)
lgs = len(ms)
ms = ms[lgs-2:lgs]
hs = "0" + str(h)
lgs = len(hs)
hs = hs[lgs-2:lgs]
dt = hs+":"+ms+":"+ss
# Clear sensor text areas
display.rectangle(5,10,127,18)
display.rectangle(5,50,90,18)
display.rectangle(5,90,80,18)
display.rectangle(5,130,80,18)
display.rectangle(5,210,115,18)
display.rectangle(5,163,90,28)
# Write digital time & sensor readings
display.text(dt,5,10,320,3)
# read the sensors
temperature, pressure, humidity = bme.read()
temp = round(temperature,1)
display.set_pen(GREEN)
display.text(str(temp)+" C",5,50,320,3)
# Convert pressure to hPa
pressurehpa = int(pressure / 100)
display.text(str(int(humidity)) +" %", 5,130,320,3)
display.text(str(pressurehpa)+" hPa",5,210,320,3)
prox, a, b, c, d, e, lux = ltr.get_reading()
lux = int(lux)
display.set_pen(CYAN)
display.text(str(lux),5,90,320,3)
# Update date/time
display.text(days[wd],5,163,320,1)
display.text(str(day)+" "+months[month-1],5,173,320,2)
display.update()
if old_m < 0 or s == 0 and m != old_m:
old_m = m
print(m%10, end='') # minute markers for debugging
if m == 59:
print('')
time.sleep(0.1)
