Robotomedium
Can you please tell me how to fix this.
importerror: cannot import name ‘RobotoMedium’ from ‘fonts.ttf’.
Did you, install those fonts?
sudo pip3 install fonts
sudo pip3 install font-roboto
Yes I have and anything else I coulð think of including fonts-roboto
Can you post the code your running please?
RPI4 32 bit and enviroplus
So, your getting that error when running the enviroplus examples?
Are you running Bookworm?
And if yes, in a virtual environment?
I’m running a lot and I mean a lot of enviro code on Pi based setups. Nothing running Bookworm though. They are mostly Pi Zero’s running older versions of Raspberry Pi OS. I set them up a while back, they run headless, and I don’t update those older version of Pi OS. No need to IMHO, they just work as intended so I leave them alone.
