# RV3028 not getting time
**URL:** <https://forums.pimoroni.com/t/rv3028-not-getting-time/11954>\
**Created:** [October 17, 2019, 4:13pm UTC](https://forums.pimoroni.com/t/rv3028-not-getting-time/11954 "2019-10-17T16:13:02Z")\
**Showing post:** 3
**Post date:** [December 17, 2019, 9:00pm UTC](https://forums.pimoroni.com/t/rv3028-not-getting-time/11954/3 "2019-12-17T21:00:06Z")
Did you get yours working? I just set mine up but its not passing the time to Raspbian?
> [@RV3028 RTC not passing time to Raspbian?](https://forums.pimoroni.com/t/rv3028-rtc-not-passing-time-to-raspbian/12479):
> I ran sudo pip install rv3028 and sudo pip3 install rv3028. Then ran the set-time.py file. And get-time.py shows the correct time. Raspbian isn’t getting the correct time from the RTC though. As a test I let Raspbian sync its time online, ran set-time.py and verified it with get-time.py. Disconnected from the Internet and shut down. On boot up the displayed time is the time it was shut down at, but get-time.py shows the correct time is stored in the RV3028? I even did the manual install, b…
_[View the full topic](https://forums.pimoroni.com/t/rv3028-not-getting-time/11954)._
