Skully/Plasma Stick 2040 W boot py program
Really like my new Skully but would like to set a different default program. I’m unfamiliar with the 2040W controller. I can load a different program (like fire.py) from Thonny but it appears that after the plasma board boots it defaults back to main.py. I’ve used systemctl on my Pi5 by not sure (or couldn’t find) the recommended settings on the 2040. Can someone point me to the procedure to change to initial program? It boots when I plug the 2040 in just runs main.py instead of the program that I used in Thonny.
Hi! It will run whatever file is saved as main.py when it’s plugged into a power source. In Thonny, save your chosen as main.py (and save it onto the device) and it will run automatically.
Remember that if you do this, you will overwrite main.py so you should save that with a different name first.
Will do. Thanks much
