[Tutorial] Managing Plasma LED color changes for system and gameslist under RetroPie
Hi Forum,
is there a way to find out, what current pattern plasmactl is running?
I did not find any command that would do so in the documentation.
With
plasmactl --pattern name
i can set a color set. Now I would like to pass that “value” to a script, that should only be executed when a certain pattern is set (or not set).
My problem is:
I am running two shell scripts calling plasmactl --pattern in different menus by calling script 1 or script 2 when choosing a list element within those menus (there is no other way of calling the scripts that I am aware of).
Menu 1 > list element > script 1 > pattern 1;
Menu 2 > list element > script 2 > pattern 2
I would like to avoid running one script if the the color is already set correctly, because there would be no need to execute it again and again while it is slowing down my pi.
I was thinking about setting a global variable but I dont know, if it would even be possible to pass such a variable between different shell scripts.
A plasma status would help …
Thanks for any ideas on that.
I came up with a different solution with the help of a friend, that implements a daemon and three scripts.
1. Daemon Script
This script monitors the status file and triggers color changes based on the current menu (Systems Menu or Gamelist Menu).
#!/bin/bash
# /home/pi/led_ram_daemon.sh
# Path to the status file in RAM
STATUS_FILE=“/dev/shm/led_ram_status.sh“
# Check if the status file exists. If not, create it.
if [ ! -f "$STATUS_FILE“ ]; then
    echo "SYSTEMSLED=OFF“ > "$STATUS_FILE“
    echo "GAMESLED=OFF“ >> "$STATUS_FILE“
fi
# Function to read the status values and apply them to the LEDs
apply_led_status() {
    # Load the current status
    source "$STATUS_FILE“
    # Check if SYSTEMSLED should be turned ON
    if [ "$SYSTEMSLED“ == „ON“ ]; then
        # Set SYSTEMSLED to the ‚systemscolor‘ pattern (no output to console)
        plasmactl --pattern systemscolor > /dev/null 2>&1
    fi
    # Check if GAMESLED should be turned ON
    if [ "$GAMESLED“ == "ON“ ]; then
        # Set GAMESLED to the ‚gamescolor‘ pattern (no output to console)
        plasmactl --pattern gamescolor > /dev/null 2>&1
    fi
# Function to check for status changes
check_status_change() {
    # Save the old status
    old_status=$(cat "$STATUS_FILE“)
    # Monitor status changes in a loop
    while true; do
        # If the status has changed, apply the new LED state
        new_status=$(cat "$STATUS_FILE“)
        if [ "$old_status“ != "$new_status“ ]; then
            apply_led_status  # Apply changes to the LEDs
            old_status=$new_status  # Set the new status as the old status
        fi
        sleep 0.1  # Wait 100 milliseconds before checking again
    done
2. Systems-LED Script
Changes LED colors when in system-selection menu
/opt/retropie/configs/all/emulationstation/scripts/system-select/led_ram_systems.sh
#!/bin/bash
# /opt/retropie/configs/all/emulationstation/scripts/system-select/led_ram_systems.sh
# Set the System-LED status to „ON“ and the Game-LED status to „OFF“
echo "SYSTEMSLED=ON“ > "$STATUS_FILE“
3. Games-LED Script
Changes LED colors when browsing roms / games
/opt/retropie/configs/all/emulationstation/scripts/game-select/led_ram_games.sh
#!/bin/bash
echo "GAMESLED=ON" > "$STATUS_FILE"
echo "SYSTEMSLED=OFF" >> "$STATUS_FILE"
Excursion: Using a status file under /dev/shm
Saving the status file in /dev/shm (temporary filesystem, stored in RAM) is improving performance and prevent wear on the SD card.
  • Speed: Reading from and writing to /dev/shm is faster than accessing files stored on the SD card, which is especially important if the script is running in a loop and frequently checking for status
    changes. This improves the responsiveness of the LED color changes without putting excessive load on the system.
  • Temporary Storage: The status file only needs to exist for the duration of the session. Once the system is rebooted, the /dev/shm directory is cleared automatically, so there is no need to manage or clean up the status file manually.
  • What is Stored in the Status File?: The status file stores the current state of the LEDs (whether the
    system is in „Systems Menu“ or „Games Menu“).
Specifically, it holds two variables:
SYSTEMSLED: „ON“ or „OFF“ (indicates whether the system LED colorset should be on or off).
GAMESLED: „ON“ or „OFF“ (indicates whether the game LED colorset should be on or off).
The file is written in a simple key-value format:
SYSTEMSLED=ON
GAMESLED=OFF
Whenever the LED state changes, the script updates this file with the new values. The daemon then reads the file, and based on its contents, updates the LED colors accordingly.
Excursion: Tradeoff between performance and responsiveness
  • Why the Delay?
    The delay ensures that the daemon does not overwhelm the system with constant checks, which could lead to excessive CPU usage and lagging while browsing roms / gameslists. By introducing a rather small delay of 100 milliseconds, the script remains quiet responsive enough to changes but does not use too many system resources.
  • Adjusting the Delay:
    One can customize the delay to fit personal preferences. To make the script more responsive (i.e., faster reaction to color changes), reduce the sleep time (e.g., sleep 0.05 for 50 milliseconds). Conversely, to improve system performance further, increase the sleep time (e.g., sleep 0.2 for 200 milliseconds). The delay is located in the check_status_change function of the daemon script.
4. Setting up the “LED RAM Daemon”
The daemon should runs automatically on system startup, with the help of systemd service. This service will start the led_ram_daemon.sh script in the background.
Location of the systemd service file:
/etc/systemd/system/led_ram_daemon.service
[Unit]
Description=LED RAM Daemon Service
After=network.target
[Service]
Type=simple
ExecStart=/home/pi/led_ram_daemon.sh
Restart=always
User=pi
Group=pi
[Install]
WantedBy=multi-user.target
Enabing the service:
sudo systemctl enable led_ram_daemon.service
Starting service manually:
sudo systemctl start led_ram_daemon.service
Logging
journalctl -u led_ram_daemon.service
5. Configuring autostart.sh for EmulationStation
In order to make sure that the system starts the daemon on boot and manages the LEDs when starting EmulationStation, there needs to be an addition in the autostart.sh file
Include before everything else
cp /home/pi/led_ram_daemon.sh /dev/shm/
/dev/shm/led_ram_daemon.sh &
This setup copies the led_ram_daemon.sh script to /dev/shm/ (a temporary in-memory filesystem) each time the system starts. Running the script from /dev/shm/ can improve its responsiveness, as accessing files in RAM is generally faster than from disk. After copying, the daemon starts in the background, and EmulationStation launches automatically.
6. Pattern Images for Plasma
Plasma uses png files for LED patterns with plasmactl command
They need to be available in /etc/plasma
For further infos see the docs
7. Final Steps
Scripts need to be executable!
After placing the scripts in their respective directories, this can be done by running:
chmod +x /home/pi/led_ram_daemon.sh
chmod +x /opt/retropie/configs/all/emulationstation/scripts/system-select/led_ram_systems.sh
chmod +x /opt/retropie/configs/all/emulationstation/scripts/game-select/led_ram_games.sh
Rebooting Pi to ensure the daemon starts properly and the LED color patterns are correctly applied.
## HAVE FUN AND ENJOY!
Final Comments & Thoughts
  1. You are very welcome to use this for your pi and plasma LED fun
  2. Any improvements are very welcome
  3. There are (for sure!) other ways of doing this but I ran into “serious” problems by trying to implement a call of plasmactl --pattern [name] within a bash-script in the game-start folder, leading to noticable performance drops and lags when calling the script each time hovering over a game from a (smaller or bigger) roms list
  4. I dont know if this could also be done with python. The plasma documentation has some hints on how to drive LEDs with pure code and not pngs but I am not sure if that method is deprecated or not.
  5. Maybe change the topic to something like “[Tutorial] Managing Plasma LED color changes for system and gameslist under RetroPie”. Unfortunately, I am not allowed to do so
I’ve changed this for you, thanks very much for sharing your instructions/scripts :)
