I am building a ‘Retro’ media centre into an Iconic Bakelite 1952 Bush TV cabinet which originally had a 9" round CRT fitted where the top an bottom were blanked off to give the impression it had a somewhat square ish screen. The aspect ratio falls somewhere between the old 4:3 and the more modern 16:9
I am using a 12" 4:3 lcd monitor as the main display and I need to create a custom aspect ratio where I can specify the height and width that I want. The underscan option in the RPi OS just underscan’s very slightly. If you look at the vintage test card on the screen, you will see some thin strips of tape creating a smaller rectangle on the screen, I need to underscan the picture to fit inside this rectangle, so everything the display displays must be inside these tape lines.
I’ve been told this can easily be done in one of the boot files but I’ve not been able to find any information for a noob like me. I am running the 64 bit RPi OS and I am using the HDMI 1 output fed into an HDMI to VGA official adaptor
Can anyone help me with precise information to do this?
TIA
