I am trying to integrate my own custom model into this repository. I have successfully gotten my model to work with the “detect” and “track” commands. However, I am trying to get my pan/tilt gimbal to pan from the -90deg position to the +90deg position, in increments of 60deg, while running the track command (tilt stays at 25deg position). Additionally, once the camera successfully detects an object and tracking begins, I want the panning command to stop.
I noticed when the track command is issued it starts in a high tilted position and slowly moves down, with no pan movement. Perhaps changing that script would work. I went into the manager.py script and figured this is the place to start.
import logging
from multiprocessing import Value, Process, Manager
import pantilthat as pth
import signal
import sys
from rpi_deep_pantilt.detect.camera import run_pantilt_detect
from rpi_deep_pantilt.control.pid import PIDController
logging.basicConfig()
LOGLEVEL = logging.getLogger().getEffectiveLevel()
RESOLUTION = (320, 320)
SERVO_MIN = -90
SERVO_MAX = 90
CENTER = (
RESOLUTION[0] // 2,
RESOLUTION[1] // 2
# function to handle keyboard interrupt
def signal_handler(sig, frame):
# print a status message
print("[INFO] You pressed `ctrl + c`! Exiting...")
# disable the servos
pth.servo_enable(1, False)
pth.servo_enable(2, False)
# exit
sys.exit()
def in_range(val, start, end):
# determine the input vale is in the supplied range
return (val >= start and val <= end)
def set_servos(pan, tilt):
# signal trap to handle keyboard interrupt
signal.signal(signal.SIGINT, signal_handler)
pan_angle = -1 * pan.value
tilt_angle = tilt.value
# if the pan angle is within the range, pan
if in_range(pan_angle, SERVO_MIN, SERVO_MAX):
pth.pan(pan_angle)
else:
logging.info(f'pan_angle not in range {pan_angle}')
if in_range(tilt_angle, SERVO_MIN, SERVO_MAX):
pth.tilt(tilt_angle)
else:
logging.info(f'tilt_angle not in range {tilt_angle}')
def pid_process(output, p, i, d, box_coord, origin_coord, action):
# create a PID and initialize it
p = PIDController(p.value, i.value, d.value)
p.reset()
# loop indefinitely
error = origin_coord - box_coord.value
output.value = p.update(error)
# logging.info(f'{action} error {error} angle: {output.value}')
# ('person',)
#('orange', 'apple', 'sports ball')
def pantilt_process_manager(
model_cls,
labels=('person',),
rotation=0
pth.servo_enable(1, True)
pth.servo_enable(2, True)
with Manager() as manager:
# set initial bounding box (x, y)-coordinates to center of frame
center_x = manager.Value('i', 0)
center_y = manager.Value('i', 0)
center_x.value = RESOLUTION[0] // 2
center_y.value = RESOLUTION[1] // 2
# pan and tilt angles updated by independent PID processes
pan = manager.Value('i', 0)
tilt = manager.Value('i', 0)
# PID gains for panning
pan_p = manager.Value('f', 0.05)
# 0 time integral gain until inferencing is faster than ~50ms
pan_i = manager.Value('f', 0.1)
pan_d = manager.Value('f', 0)
# PID gains for tilting
tilt_p = manager.Value('f', 0.15)
tilt_i = manager.Value('f', 0.2)
tilt_d = manager.Value('f', 0)
detect_processr = Process(target=run_pantilt_detect,
args=(center_x, center_y, labels, model_cls, rotation))
pan_process = Process(target=pid_process,
args=(pan, pan_p, pan_i, pan_d, center_x, CENTER[0], 'pan'))
tilt_process = Process(target=pid_process,
args=(tilt, tilt_p, tilt_i, tilt_d, center_y, CENTER[1], 'tilt'))
servo_process = Process(target=set_servos, args=(pan, tilt))
detect_processr.start()
pan_process.start()
tilt_process.start()
servo_process.start()
detect_processr.join()
pan_process.join()
tilt_process.join()
servo_process.join()
if __name__ == '__main__':
pantilt_process_manager()
Any help? I’m new to coding so some in-depth steps would be appreciated.
Thanks!
