Haha I have the problem all the time with forgetting what I did and how I did it, and end sometimes up with installing Raspberry OS 3 times a day. I also put the display on blue light, until I"m bored of it then I probably switch to green or red or sth. in between.
The weather clock sounds interesting, especially the color changes!
The Y button is so far unused, you could code it to change color when pressed. ;)
Most of my Pi build pictures are here if you want to have a look see.
https://1drv.ms/u/s!AjOYwiwlwDtpgUMsp2qnevKpGEHb?e=Wd9eSc
lol, itās my Microsoft Public OneDrive folder.
I have two weather clocks, one stand alone indoor one and a portable battery powered version. The indoor one doesnāt have the light or UV sensor on it. The LED shim can be set to show temperature or barometric pressure. Toggled with the Sense H joystick. Itās usually set to show the pressure in the winter, and temperature in the summer.
To put colorchange on the Y button might be a nice thing to try, next to my Ubercorn, Pirate Audio and Sphero RVR / Pi projects, Too many things, too less time. But some nice projects you did!
I hear you. My wife just chuckles to herself when Iām taking things out on my back deck to tinker with in under my gazebo. I make half a dozen or so trips taking stuff out. Laptop, portable weather clock, maybe my Pirate radio and one or two other Pi projects. Then carry it all back in a couple of hours latter. =)
I have finally got all the pieces for this,
https://learn.pimoroni.com/tutorial/sandyj/build-an-itty-bitty-beat-box
so its moved to the top of my list of projects to finish. Just the software to install and setup.
After that I have some breakout garden stuff I want to get back too.
Pressing Y button now cycles though different colors. Changing the Y = line changes the default color it will start with, Y = 3 is Blue. Editing the r, g, b = lines will change the color assigned to that value for Y. I donāt know why, timing I guess, but the occasional button press is missed? It doesnāt crash the program so not a big deal.
#!/usr/bin/env python3
import sys
import os
import time, datetime
import RPi.GPIO as GPIO
from PIL import Image, ImageDraw, ImageFont
from unicornhatmini import UnicornHATMini
unicornhatmini = UnicornHATMini()
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
GPIO.setup(5, GPIO.IN, pull_up_down = GPIO.PUD_UP) # A
GPIO.setup(6, GPIO.IN, pull_up_down = GPIO.PUD_UP) # B
GPIO.setup(16, GPIO.IN, pull_up_down = GPIO.PUD_UP) # X
GPIO.setup(24, GPIO.IN, pull_up_down = GPIO.PUD_UP) # Y
X = 0
Y = 3 # Blue
B = 0.5
def Dim(channel):
global B
B = B - 0.1
if B <= 0.1:
B = 0.1
unicornhatmini.set_brightness(B)
def Bright(channel):
global B
B = B + 0.1
if B >= 1.0:
B = 1.0
def Shutdown(channel):
global X
X = 1
def color(channel):
global Y
Y = Y + 1
GPIO.add_event_detect(5, GPIO.FALLING, callback = Dim, bouncetime = 2000)
GPIO.add_event_detect(6, GPIO.FALLING, callback = Bright, bouncetime = 2000)
GPIO.add_event_detect(16, GPIO.FALLING, callback = Shutdown, bouncetime = 2000)
GPIO.add_event_detect(24, GPIO.FALLING, callback = color, bouncetime = 2000)
rotation = 180
if len(sys.argv) > 1:
try:
rotation = int(sys.argv[1])
except ValueError:
print("Usage: {} <rotation>".format(sys.argv[0]))
sys.exit(1)
unicornhatmini.set_rotation(rotation)
display_width, display_height = unicornhatmini.get_shape()
font = ImageFont.truetype("/home/pi/5x7.ttf", 8)
offset_x = 0
if Y > 4:
Y = 0
if Y == 0:
r, g, b = (255, 0, 0) # Red
elif Y == 1:
r, g, b = (255, 255, 0) # Yellow
elif Y == 2:
r, g, b = (0, 255, 0) # Green
elif Y == 3:
r, g, b = (0, 0, 255) # Blue
elif Y == 4:
r, g, b = (0, 255, 255) # Aqua
if offset_x == 0:
text = time.strftime("%A %B %-d %-I:%M %p")
text_width, text_height = font.getsize(text)
image = Image.new('P', (text_width + display_width + display_width, display_height), 0)
draw = ImageDraw.Draw(image)
draw.text((display_width, -1), text, font=font, fill=255)
else:
for y in range(display_height):
for x in range(display_width):
if image.getpixel((x + offset_x, y)) == 255:
unicornhatmini.set_pixel(x, y, r, g, b)
else:
unicornhatmini.set_pixel(x, y, 0, 0, 0)
offset_x += 1
if offset_x + display_width > image.size[0]:
offset_x = 0
if X == 1:
unicornhatmini.set_all(0, 0, 0)
unicornhatmini.show()
time.sleep(30)
time.sleep(0.05)
# Last edited on June 13th 2020
# added color chnage function to Y button
# run sudo crontab -e
# add
# @reboot python3 /home/pi/scroll_clock.py &
Nice one! took me some time to get it working because I thought it was only a small change in the script but then it didnāt work. So had to read the script good and then found all the changes and now it works :)
That was one of the easier changes. No more buttons left now though, lol. Unless you add a button shim etc.
Hmm, that would be one way to avoid having to drill holes in the diffuser, and no having to use a toothpick.
Haha yeah button shim looks like it fits perfectly in the pibow coupe and diffuser on top
Added one more color option for Y = 5.
Iām not saying what it does though.
This was really hard to pull off.
import sys
import os
from colorsys import hsv_to_rgb
X = 0
Y = 0
B = 0.3
def Dim(channel):
global B
B = B - 0.1
if B <= 0.1:
B = 0.1
global B
B = B + 0.1
if B >= 1.0:
B = 1.0
global X
X = 1
def color(channel):
global Y
Y = Y + 1
rotation = 180
try:
except ValueError:
sys.exit(1)
offset_x = 0
if Y > 5:
Y = 0
if Y == 0:
elif Y == 1:
elif Y == 2:
r, g, b = (0, 205, 0) # Green
elif Y == 3:
elif Y == 4:
r, g, b = (255, 140, 0) # Orange
if offset_x == 0:
if Y == 5:
hue = (time.time() / 10.0) + (x / float(display_width * 2))
r, g, b = [int(c * 255) for c in hsv_to_rgb(hue, 1.0, 1.0)]
else:
if Y < 5:
else:
offset_x += 1
offset_x = 0
if X == 1:
time.sleep(30)
time.sleep(0.05)
# Last edited on June 14th 2020
# add
Again took some time to see all the changes in the code ;) but wow, what a nice colorchange now. I also checked the option for the button shim, might need some modification on the pibow but then it should fit, the only problem is that I then also have to build a little stand so I can flip the Pi, put a 90 degree usb-cable and the buttons are on top.
To be honest I borrowed that code from the text.py example.
It took a lot of trial and error to get it integrated into my code though.
I noticed that too, if you use the button shim you have to flip the Unicorn Mini 180.
For my setup I would have to and that puts my Pi Zeroās power jack facing down.
Not an ideal setup for me so I wonāt be adding a button shim any time soon.
Just FYI the button shim needs to be soldered.
Ah damn I thought it might work like the fan shim, just put it on the Pi headers and the HAT on top. My solder skills are on the same level as my Python skills. Mistakes in Python are easier to correct than mistakes during soldering.
Iām not all that fussy for that friction fit shim stuff. Itās about 50 50 here Fan Shim wise, some work some donāt. I have one I had to solder to a header to get it fully functional.
If the Fan shim had the full length header like the LED Shim I think it would have a better chance of working right out of the box.
Also think its misleading calling the Button Shim a shim, as it has to be soldered to work.
EDIT: Iām a retired electronic technician, soldering is easy peasy for me, been doing it for 40+ years lol.
I got my temperature readout added. What a Time I had getting that to work.
It would get stuck and just endlessly repeat one of the other message.
Humidity and pressure readouts are next.
The color cycle function is removed from this file, and I have to add back in the incremental brightness. Iāll strip out the exit code once I get it finalized.
import sys
import os
try:
from smbus2 import SMBus
except ImportError:
from smbus import SMBus
from bme280 import BME280
bus = SMBus(1)
bme280 = BME280(i2c_dev=bus)
# button_map
# 5: "A",
# 6: "B",
# 16: "X",
# 24: "Y"}
X = 0
Y = 0
M = 0
def Dim(channel):
unicornhatmini.set_brightness(0.5)
unicornhatmini.set_brightness(1.0)
global X
X = 1
def Exit(channel):
global Y
Y = 1
GPIO.add_event_detect(24, GPIO.FALLING, callback = Exit, bouncetime = 2000)
rotation = 0
try:
except ValueError:
sys.exit(1)
offset_x = 0
if offset_x == 0 and M == 0:
text = time.strftime("It's %A %B %-d %-I:%M %p")
elif offset_x == 0 and M == 1:
T = bme280.get_temperature()
T = round(T)
if T <= 0:
r, g, b = [0, 0, 255] # Blue
elif T > 0 and T < 13:
r, g, b, = [255, 255, 0] # Yellow
elif T >= 13 and T < 25:
r, g, b = [0, 255, 0] # Green
elif T >= 25 and T < 30:
r, g, b = [255, 50, 0] # Orange
elif T >= 30:
r, g, b = [255, 0, 0] # Red
text = ("and the Temperature is %sc") % (T)
else:
else:
time.sleep(0.05)
offset_x += 1
offset_x = 0
M = M + 1
if M == 2:
M = 0
if X == 1:
time.sleep(30)
if Y == (1):
raise SystemExit
time.sleep(30)
# Last edited on June 16th 2020
# added temperature display
# add
Looks nice, do I understand right that the "and the Temperature is %sc" part is an PIL image? And the %sc is something imported from the SMBus/bme280?
The āand the Temperature isā displays as text. The %s displays whatās after the other % sign out side the brackets. % (T) displays the variable T which is the rounded off temperature. Taken from the BME280
T = round(T)
And the c (more text) to denote degrees Celsius. Have a look at this.
This will work with a BME680 etc, with some code changes.
import sys
import os
try:
except ImportError:
bus = SMBus(1)
# button_map
# 5: "A",
# 6: "B",
# 16: "X",
# 24: "Y"}
X = 0
Y = 0
M = 0
def Dim(channel):
global X
X = 1
def Exit(channel):
global Y
Y = 1
rotation = 0
try:
except ValueError:
sys.exit(1)
offset_x = 0
T = round(T)
if T <= 0:
elif T >= 30:
elif offset_x == 0 and M == 2:
H = bme280.get_humidity()
H = round(H)
if H < 30:
elif H >= 30 and H <= 60:
elif H > 60 and H < 80:
r, g, b = [255, 255, 0] # Yellow
elif H >= 80:
text = ("with %s%% Humidity") % (H)
elif offset_x == 0 and M == 3:
p = bme280.get_pressure()
P = round(p)
if P > 0 and P < 982: # Very Low
elif P >= 982 and P < 1004: # Low
elif P >= 1004 and P < 1026: # Mid Range
elif P >= 1026 and P < 1048: # High
elif P >= 1048: # Very High
text = ("@ %smb Pressure") % (P)
else:
else:
time.sleep(0.05)
offset_x += 1
offset_x = 0
M = M + 1
if M == 4:
M = 0
if X == 1:
time.sleep(30)
if Y == (1):
raise SystemExit
time.sleep(30)
# added temperature humididty and pressure display
# add
Woot, I an pumped right now. I also managed to add some custom messages to the pressure messages. is very low : Storm Watch, is low : Possible Precipitation etc.
Next step is to try and port this over to run on my Unicorn Hat HD. =)
If you get it running on te Unicorn HAT HD let me know, because then it should work on my Ubercorn, and I have a good reason to buy those sensors :)
I should be trying to port to my Unicorn HD some time latter this week or early next week.
Iāll let you now how it goes.
Finished up the code to move my Unicorn Mini into my portable weather clock. I had a few issues to sort out to get it fully functional. Iām happy with how it works but I have a power issue.
If I power it via an official 2.5A supply plugged into the Pi A+ all is fine. Wonāt run on powerboost though, 1A isnāt enough. Even on my power supply plugged into the back I got flashing undervolt warnings.
I have two things to fix. I need to switch to the non charging version of the PowerBoost, it can supply 2A. And I need to replace the power wires going from the PowerBoost to the Pi with heavier ones. I used jumpers and they just arenāt thick enough.
I have one of these and may swap it in place of the powerboost.
