Also strange: your clients seem to open a connection (the accept()call returns) and then don’t send any data for one minute?!
I have to be more specific on the timeout: you can set a timeout on the server-socket (s in your code), and on the socket that is returned by the accept()-call (cl in your code). The timeout on the server socket will give you fast-fail behavior on accept(). the timeout on cl will close the connection if no data arrives.
To end my bombardment prattling on about the async stuff I give you a final snippet (with some sympathies, though I hope it may help:) . Actually I’ve been meaning to give the microdot async web server a go, so I installed it on one pico, and created an async client on another so I give these 2 snippets as examples. Of course you would need to install the microdot and the aiohttp modules for the snippets to work.
The sever program
# default microdot port is 5000
# view in browser with - e.g. http://10.0.1.66:5000
import asyncio
from microdot import Microdot
# do your own code for the wifi connection
import wifi_connect as wifi
status = wifi.wlan_connect()
print('network status: ', status)
# create a simple server
app = Microdot()
@app.route('/')
async def index(request):
return 'Hello, world!'
async def main():
# start the server in a background task
server = asyncio.create_task(app.start_server())
# ... do other asynchronous work on the server pico here ...
# cleanup before ending the application
await server
try:
asyncio.run(main())
except KeyboardInterrupt:
print('Ctl C')
finally:
print('finally is being actioned')
asyncio.new_event_loop()
And the client program:
import aiohttp
import asyncio
# the URL of my pico server
URL = "http://10.0.1.66:5000"
print(URL)
async def fetch(client):
async with client.get(URL) as resp:
assert resp.status == 200
return await resp.text()
async def do_presto_things():
count = 1
print('working away - count =',count)
count +=1
await asyncio.sleep(2)
async def do_socket_stuff():
async with aiohttp.ClientSession() as client:
html = await fetch(client)
print(html)
await asyncio.sleep(1)
async def main():
asyncio.create_task(do_presto_things())
asyncio.create_task(do_socket_stuff())
await asyncio.sleep(0)
try:
asyncio.run(main())
print('Ctl C')
finally:
Ok, a bit of fun and some more snippets to tuck away in my examples file. But I hope it gives a flavour of the async coding that allows full concurrent programming and as @bablokb mentioned, even if not of any use for your current program it may come in handy for some future project.
