Issue installing blinkt
Hi Guys
Installed hat but… blinkit directory empty )even though i said Y to full install.
Im getting this message.
Installing Blinkt! library for Python 3…
_ File “/usr/bin/pip3”, line 9, in _
_ load_entry_point(‘pip==1.5.6’, ‘console_scripts’, ‘pip3’)()_
_ File “/usr/lib/python3/dist-packages/pkg_resources.py”, line 356, in load_entry_point_
_ return get_distribution(dist).load_entry_point(group, name)_
_ File “/usr/lib/python3/dist-packages/pkg_resources.py”, line 2476, in load_entry_point_
_ return ep.load()_
_ File “/usr/lib/python3/dist-packages/pkg_resources.py”, line 2190, in load_
_ [‘name’])_
_ File “/usr/lib/python3/dist-packages/pip/init.py”, line 74, in _
_ from pip.vcs import git, mercurial, subversion, bazaar # noqa_
_ File “/usr/lib/python3/dist-packages/pip/vcs/mercurial.py”, line 9, in _
_ from pip.download import path_to_url_
_ File “/usr/lib/python3/dist-packages/pip/download.py”, line 25, in _
_ from requests.compat import IncompleteRead_
ImportError: cannot import name 'IncompleteRead’
Python 3 library install failed!
If problems persist, visit forums.pimoroni.com for support
Hardware tested and work fine … not a major issue but can you assist please
BTW nice product with mini black hat
Regards
Allan
yes, if the scripts exits while trying to install the library itself, in this case for python3 specifically, then it does not complete, including install of examples.
… what you have there looks like an issue with pip itself, or pypi (though the later should interfere with lib install for python2 as well, so likely the former).
what happens if you run:
sudo pip3 install blinkt
tried sudo pip3 blinkt … and now ave this message
pi@raspberrypi:~ $ sudo pip3 blinkt
return ep.load()
[‘name’])
ImportError: cannot import name ‘IncompleteRead’
Btw I installed envirophat (a few weeks ago) and that runs fine.
Searching around the interweb I found some posts hinting at version discrepancies related to the requests module. What do you get when you run:
pip3 list | grep requests
also, getting a list of where modules are loaded from might shed some lights on the matter, possibly:
python3 -c "import sys; print(sys.path)"
Many thansk for the reply.
First ran pip 3 and got this …
return ep.load()
[‘name’])
File “/usr/lib/python3/dist-packages/pip/vcs/mercurial.py”, line 9, in <module
then ran …
python3 -c “import sys; print(sys.path)”
and got this…
[‘’, ‘/usr/local/lib/python3.4/dist-packages/iwlib-1.5-py3.4-linux-armv7l.egg’, ‘/usr/local/lib/python3.4/dist-packages/jsonpickle-0.9.2-py3.4.egg’, ‘/usr/local/lib/python3.4/dist-packages/netifaces-0.10.4-py3.4-linux-armv7l.egg’, ‘/usr/local/lib/python3.4/dist-packages/psutil-0.5.0-py3.4-linux-armv7l.egg’, ‘/usr/local/lib/python3.4/dist-packages/requests-2.9.1-py3.4.egg’, ‘/usr/local/lib/python3.4/dist-packages/myDevices-0.1.20741-py3.4.egg’, ‘/usr/local/lib/python3.4/dist-packages/WebIOPi-0.7.22-py3.4-linux-armv7l.egg’, ‘/usr/lib/python3.4’, ‘/usr/lib/python3.4/plat-arm-linux-gnueabihf’, ‘/usr/lib/python3.4/lib-dynload’, ‘/usr/local/lib/python3.4/dist-packages’, ‘/usr/lib/python3/dist-packages’]
sorry to be ignorant i haven’t got a clue what all this means
Btw have run most of the examples fro Git and everything seems to be working although i have no idea how that binary clock works:-(
Regards
Allan
according to that output your version of requests is significantly newer than the version included with Raspbian, and it seems incompatible with pip 1.5.6
how you can resolve this issue is not clear to me, with pip3 in a broken state. I am reluctant to advise you to delete usr/local/lib/python3.4/dist-packages/requests-2.9.1-py3.4.egg although I suspect that will be one of the required step, if not fully sufficient to get things back on track.
