A useful script for RGB displays
hi all,
After searching the Internet for one, I wrote a quick Python module to convert a value (most likley a temperature) to a cold-hot RGB colour - I’ve found this useful on the DOTHAT for representing the Pi’s internal CPU temp and also outside weather. Could be used for a lot of other things. The module has two functions - temp_rgb - takes a value, and a min-max range, and outputs an RGB tuple. it rebases the value you enter depending on the min/max range.
The other “get_temp”, returns the CPU temperature of the Pi.
(Gist: https://gist.github.com/philipok-1/99de9fa271a27e17b0ff62fbe2c0e3e6)
PS - the array of RGB colours was adapted from the excellent blog:
http://web-tech.ga-usa.com/2012/05/creating-a-custom-hot-to-cold-temperature-color-gradient-for-use-with-rrdtool/
Unfortunately, your gist is full of unformatted javascript, writing the text of your Python code. You need to take the .js off the end.
Here’s an updated link: https://gist.github.com/philipok-1/99de9fa271a27e17b0ff62fbe2c0e3e6
yes! thanks, just realised… reposted.
My first post - sorry…
unfortunately it doesn’t seem to be working for me.
I just get the error list index is out of range
import rgb_temp as t
temp=float(t.get_temp())
t.temp_rgb(int(temp),20,45)
time.sleep(1)
I also edited your file to this
import re, subprocess
rgb_array=[(0, 100, 255), (0, 116, 255), (0, 132, 255), (0, 148, 255), (0, 164, 255), (0, 180, 255), (0, 196, 255), (0, 212, 255), (0, 228, 255), (0, 255, 244), (0, 255, 208), (0, 255, 168), (0, 255, 131)]
def temp_rgb(temp, min, max):
    temp=int(temp)
    if temp<min:
            temp=min
    elif temp>max:
            temp=max
    index = (((temp - min) * (53 - 0)) / (max - min)) + 0
    output=rgb_array[index]
    return output
def get_temp():
    temp=subprocess.check_output(["/opt/vc/bin/vcgencmd measure_temp"], shell=True)
    out=re.search(r'\d+\.\d+', temp)
    return str(out.group(0))
def main():
print temp_rgb(-20, -5, 30)
if name == “main”:
    main()
as there were a few errors I find
thanks
Will
Great Idea by the way can’t wait to get it working as it will be really usefull for A project of mine!
ah massive apologies - my gist cut the RGB array off at the end - fixed it now, should be working. There are 53 RGB tuples in the data
P
