Automation HAT, analog read incredible slow?
Hi guys,
First post :-) Got me a Rasp 4 for Xmas - with the Automation HAT, very nice!
My first project is that I need to log 4 “digital” signals - the Automation HAT only has 3 digital IN, so I thought I’d use one Analog In as well.
Added the analog read into my Phyton script and it works - but my “gut feeling” is that the analog read is about 1000 times slower than the digital read? can that be right?
I need all 4 inputs to be as “time”-synchronized as possible - I’ll log their respective “high times”, which will be tricky if the analog one is as slow as a turtle…
help ?!
// Lazze
What voltage / logic level are the signals your reading?
Basically everything that is more than +1v is “high”.
I have 2 options, a 5v signal or a 24v signal that comes from a switchboard.
Do you have a suggestion for Another HAT that has more digital Inputs? buffered and handles up to 24v
// Lazze
I had noticed that GPIO 25 was bought out to a contact point on the Automation hat. It could be used as a digital input but it will only tolerate a max of 3.3V. 5v will damage it so thats out.
The schematic for the Automation Hat is here and it shows what’s used to make the buffered inputs. You could likely make up a fourth circuit. If you can source the parts and know how to solder etc.
I found this but its all analog.
